October 9, 2000, 22:23 |
AUSM scheme ? Central Scheme
In last years, I have developped CFD flowfield analysis software using JST scheme which is suitful for transonic speed , now I want to extend it to simulate the supersonic flows and I find it does not work well , so I want to implement AUSM scheme, but I found it is difficult to deal with the stagnent point condition and the iteration suddenly interruptted by Nan , So my question is : 1) Is Central Scheme suit for supersonic ( Ma = 4 ) flow calculation? 2) How about AUSM scheme (espacially about its robust)? 3)Is there any special treatment about the AUSM scheme near the stagnent point ?
October 11, 2000, 09:49 |
Re: AUSM scheme ? Central Scheme
The inventor of AUSM Men-sing Lou (spelling might be incorrect) had posted a message here a few days back. You should send him email. I think there have been lots of improvements over the basic AUSM, by the Dr. Lou and also others. ciao, chidu... |
October 11, 2000, 12:16 |
Thanks for your advice and I will send e-mail to Dr Liu
October 13, 2000, 00:31 |
Boling,
It is not fair to say that the JST scheme works for the transonic range but not ofr supersonic flows. I know personally that the JST scheme works well even for hypersonic Mach numbers (perfect gas) with of course some tuning of the AD term coefficients. Please look at the literature carefull especially Radespiel & others. The more likely problem in your case is the implememntation of boundary conditions in the supersonic case. Implementation of AUSM or AUSM+ is not very straightforward. This is not to discourage you from doing so, but if you have problems making the JST scheme work in cases it should work, you may find that AUSM experience might be similar. Ravichandran |
October 13, 2000, 07:18 |
Hello
JST scheme is fine for supersonic flow. AUSM scheme is very nice at the stagnation point. I think your failure may caused by another reason. Please check grid quality near the stagnation point. If the fighly distorte mesh, or grid lines are crossed, then any scheme can produce unphysical value, such as negative density .. Then NAN(Not a number) will appear on screen. Or Print out intermediate values in your program, and find the place where physics break down. T. Matsuzawa. |
September 9, 2009, 20:06 |
#6 | |
aleem
sir i am trying to develop 2d euler code for ausm scheme but i had a problem of convergance can u help me out where i am wrong |
January 7, 2016, 03:39 |
garry
Rep Power: 13 |
can you help me with my ausm code? Thanks very much.
http://www.cfd-online.com/Forums/mai...tml#post579860 |
January 7, 2016, 03:41 |
garry
Rep Power: 13 |
Is your question solved? Can you see my code and tell me the mistake? Appreciate it very much.
Upwind, central, QUICK scheme for Re~10000 | quarkz | Main CFD Forum | 4 | June 23, 2011 16:04 |
Definition of limiter function for central dirrerencing scheme | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | January 5, 2009 12:08 |
Upwing vs Central scheme | Ruben | Main CFD Forum | 15 | August 8, 2005 07:13 |
Central Differencing Scheme in Fluent | alice | FLUENT | 2 | March 21, 2004 08:30 |
AUSM PW+ scheme | P. Louda | Main CFD Forum | 3 | March 16, 2004 13:06 |
