MPICH
Old   September 29, 2000, 03:58
Default MPICH
Junseok Kim
I just wonder can I use MPICH in my department Unix network without bothering system manager?
I visited below site, and followed its implement direction, and I am lost cause there are a lot of options. And when I compilied, I got a lot of error messages.
http://www-unix.mcs.anl.gov/mpi/mpich/
Kim
Old   November 5, 2000, 23:07
Default Re: MPICH
Ferenc Gyurcsan
Hi, Yes,I believe you should be able to use MPICH without disturbing your sys admins. As long as there are all the needed things installed, like c compiler, and all the needed libraries. If you have trouble compiling MPICH, maybe you could give LAM a try. I think it's even faster than MPICH, if you have simple TCP/IP, no Myrinet or something fancy like that. I used LAM with good success.
--Ferenc
MPICH distributed optimization Luk_Fiz CFX 2 April 27, 2009 03:50
distributed mpich problem Trevor CFX 15 January 9, 2007 18:08
MPICH Parallel Run Error on the Windows Server2003 Saturn CFX 3 August 29, 2006 09:42
MPICH problem (CFX-5.7.1) Jesper CFX 7 April 16, 2005 06:04
MPICH : undefined reference to.. Vincent Siemens 3 March 24, 2005 13:30
