FloatingPoint
Old   October 19, 1998, 14:54
Default FloatingPoint
John
I am now doing mesh generation on the "disgusting" surface. Can anybody tell me how to float the point on the boundary of this surface.
Thanks, John
Old   October 19, 1998, 15:16
Default Re: FloatingPoint
John C. Chien
As a principle, try to build the geometric model with smaller and simpler surface patches. At that point, it is easier to distribute points along the edge curves of the surface patch for a successful surface mesh generation. You need that for a successful volume mesh generation. " divide the surface into smaller , simpler surface patches ". For complex geometry, sometimes you need to work with several hundreds small surface patches. ( this may not be the right answer for you because of the definition of your question.)
Old   October 21, 1998, 17:16
John
Thanks for your response. However your idea may be more suitable for fixed boundary as I am not using it. But I 'll try to put into my problem.
Thanks again.
