FDM. & FVM.
Old   September 12, 2000, 10:42
Default FDM. & FVM.
H.Setthapong
Can anyone tell me,How difference between Finte difference method and Finite volume method.?
Old   September 13, 2000, 01:05
Default Re: FDM. & FVM.
Istadi
It is any difference between FDM and FVM. In the FDM method, the differential terms are numerically approach directly by Taylor series, i.e. first order or second order. The second order have a good approximation with less error. In the FVM, the differential terms are firstly integrated analitically in the control volume between left face to right face. After that, the differential terms are numerically approximate by Taylor series or schemes , i.e. hybrid, power law, upwind differencing, etc, by applied conservation of mass and energy throughout control volume.
In the FVM, it is more and more rule of law that we must obey to get stabil and real solution.
Old   September 13, 2000, 02:20
sameer mohrir
You can refer to question posted by myself on 17th Aug 00.regarding same subject
regards
sameer mohrir
Old   September 13, 2000, 11:01
H.Setthapong
Hello,Istadi Is that means the SIMPLER METHOD with POWER LAW is also FINITE VOLUME METHOD.? Thank for your help.
H.setthapong
Old   September 13, 2000, 23:26
Istadi
In the FVM, there are SIMPLE method and SIMPLER method. Patankar (1980) said that SIMPLER method is modified of SIMPLE method in order to achieve fast convergence.
Old   September 14, 2000, 07:47
Sebastien Perron
As far as I know,
1) The simple (Simpler, Simplec etc) method is not a numerical scheme (FVM, FDM FEM). It is an algorithm related to projection methods, these are used to solve incompressible flow.
2) But it is widely used in FVM codes to solve incompressible flow. (That is why when people say they use Simple or Simpler we often beleive it is in the context of FVM)
3) It is also used in some FEM codes to solve incompressible flow.
Old   September 15, 2000, 06:37
Istadi
I agree with your opinion that SIMPLE or SIMPLER is not a numerical scheme. As far as I know that the numerical scheme are power law scheme (PLS), upwind difference scheme (UDS), hybrid scheme, etc.
openfoam -> fem, fvm, fdm? tH3f0rC3 OpenFOAM 4 September 3, 2015 03:51
Atleast 5 general Diffrences between FVM, FEM, FDM RAJ FLUENT 2 October 7, 2005 09:25
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 19:28
FVM and FDM Zhu Main CFD Forum 2 April 16, 2002 08:24
FVM (vs) FDM for compressible flows Rajani Kumar Akula Main CFD Forum 6 April 12, 2002 02:56
