December 8, 2024, 21:21 |
Varying the velocity by each time
Chandra Napitupulu
Rep Power: 3 |
I had created the velocity from 1 knot to 12 knot (so it will write the folder of parameter form t=0 to t=11) by type timeVaryingMappedFixedValue;
but it gives me an error message HTML Code:
inlet { type timeVaryingMappedFixedValue; value uniform (0 0 0); // Default velocity value (optional) table ( (0.0 (-0.514444 0 0)) // At time = 0, velocity is -1 knot (-0.514444 m/s) (1.0 (-1.028888 0 0)) // At time = 1, velocity is -2 knots (-1.028888 m/s) (2.0 (-1.543333 0 0)) // At time = 2, velocity is -3 knots (-1.543333 m/s) (3.0 (-2.057777 0 0)) // At time = 3, velocity is -4 knots (-2.057777 m/s) (4.0 (-2.572222 0 0)) // At time = 4, velocity is -5 knots (-2.572222 m/s) (5.0 (-3.086666 0 0)) // At time = 5, velocity is -6 knots (-3.086666 m/s) (6.0 (-3.601111 0 0)) // At time = 6, velocity is -7 knots (-3.601111 m/s) (7.0 (-4.115555 0 0)) // At time = 7, velocity is -8 knots (-4.115555 m/s) (8.0 (-4.630000 0 0)) // At time = 8, velocity is -9 knots (-4.630000 m/s) (9.0 (-5.144444 0 0)) // At time = 9, velocity is -10 knots (-5.144444 m/s) (10.0 (-5.658888 0 0)) // At time = 10, velocity is -11 knots (-5.658888 m/s) (11.0 (-6.173333 0 0)) // At time = 11, velocity is -12 knots (-6.173333 m/s) (12.0 (-6.687777 0 0)) // At time = 12, velocity is -13 knots (-6.687777 m/s) (13.0 (-7.202222 0 0)) // At time = 13, velocity is -14 knots (-7.202222 m/s) (14.0 (-7.716666 0 0)) // At time = 14, velocity is -15 knots (-7.716666 m/s) ); } |
December 8, 2024, 22:15 |
Lucky
Rep Power: 66 |
you are using the wrong BC type
use fixedValue or uniformFixedValue and supply the table timeVaryingMappedFixedValue "Maps" data from a table onto a patch, in space and space&time. Since you are not mapping onto a patch, it is the wrong BC. |
December 8, 2024, 22:40 |
Chandra Napitupulu
Rep Power: 3 |
Pardon, I have already rewrited the type of BC. but i'm just doubt for the outlet BC, because, it set into outletPhaseMeanVelocity, but unfortunately, i don't know how to set the scalar of "Umean"?
Example If the interval time write at t=1, U value= (-0.514 0 0) at inlet and Umean and U value are 0.514 and (-0.514 0 0 0). If the interval time write at t=2, U value= (-1.028 0 0) at inlet and Umean and U value are 1.028 and (-1.028 0 0 0). And so on Sorry for confused interpretation |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 10:10 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
