the total pressure at the wall is higher than inlet?? |
December 6, 2024, 01:50 |
Rep Power: 3 |
In the calculation of Fluent, the total pressure increases without external operation, but there is a point on the wall where the total pressure is higher than the total pressure of the incoming flow.(Not too much, inlet use pressure inet with total P = 9026.7Pa, Operating P = 0, total P at a point in the wall = 9026.86Pa)
and It's also curious that the formula for the total pressure-static pressure of an ideal gas should be related to the Ma number, Ma=0 on the wall, so the total pressure should be equal to the static pressure, but it's not; |
fluent, static and dynamic, total pressure increase |
Total pressure Inlet vs opening pres. and Dirn | jins9158 | CFX | 0 | March 7, 2022 20:23 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 07:33 |
Higher Area- weighted Outlet total pressure than Inlet | waseeqsiddiqui | FLUENT | 11 | January 11, 2019 11:27 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Pressure Inlet: question about total pressure | I-mech | FLUENT | 0 | July 13, 2014 06:38 |
