My case doesn't castellated fully
Old   December 2, 2024, 21:42
Cool My case doesn't castellated fully
Leonardo Biscaino
leobiscaino is on a distinguished road
Hello CFD users, I’m new to CFD and I’m trying to create a mesh for the case described below. As you can see, the trailing edge is not working as expected.
Block mesh dict:
| \\ / O peration | Version: v2312 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
scale 1;
vertices
(0 0 0)
(12.04 0 0)
(12.04 -12.04 0)
(0 -12.04 0)
(0 0 -12.04)
(12.04 0 -12.04)
(12.04 -12.04 -12.04)
(0 -12.04 -12.04)
blocks
hex (0 1 2 3 4 5 6 7) (100 100 100) simpleGrading (1 1 1)
edges
boundary
topAndBottom
type patch;
faces
(3 7 6 2)
(1 5 4 0)
inlet
type patch;
faces
(0 4 7 3)
outlet
type patch;
faces
(2 6 5 1)
symFront
type patch;
faces
(4 5 6 7)
symBack
type symmetryPlane;
faces
(0 3 2 1)
SnappyHexMeshDict
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap false;
addLayers false;
// Geometry. Definition of all surfaces.
geometry
blade_0.stl
type triSurfaceMesh;
name blade;
refinementBox
type searchableBox;
min (4 -4 -8);
max (8 0 -4);
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
maxLocalCells 100000;
maxGlobalCells 2000000;
minRefinementCells 100;
nCellsBetweenLevels 3;
// Explicit feature edge refinement
features
file "blade_0.eMesh";
level 3;
// Surface based refinement
refinementSurfaces
blade
level (9 9); // Refinamento padrão para toda a superfície
regions
tips { level (13 13); }
patch_cut { level (13 13); }
patch_upper { level (13 13); }
patch_le { level (11 11); } // Refinamento mais fino para borda de ataque
patch_lower { level (13 13); }
resolveFeatureAngle 30;
// Region-wise refinement
refinementRegions
refinementBox
mode inside;
levels
(1 8)
// Mesh selection
locationInMesh (6.02 -2 -6.02);
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
nSmoothPatch 3;
tolerance 1.0;
nSolveIter 60;
nRelaxIter 5;
// Settings for the layer addition.
addLayersControls
relativeSizes true;
layers
blade
nSurfaceLayers 5;
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.1;
nGrow 0;
featureAngle 60;
slipFeatureAngle 30;
nRelaxIter 3;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedialAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
// Mesh quality controls
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality 1e-30;
minArea -1;
minTwist 0.05;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
// Advanced settings
mergeTolerance 1e-6;
SurfaceFeatureExtract
| \\ / O peration | Version: v2206 |
FoamFile
version 2.0;
format ascii;
class dictionary;
object surfaceFeatureExtractDict;
blade_0.stl
// How to obtain raw features (extractFromFile || extractFromSurface)
extractionMethod extractFromSurface;
// Mark edges whose adjacent surface normals are at an angle less
// than includedAngle as features
// - 0 : selects no edges
// - 180: selects all edges
includedAngle 150;
// Write options
// Write features to obj format for postprocessing
writeObj false;
leobiscaino is offline   Reply With Quote
Old   December 3, 2024, 03:55
M
AtoHM is on a distinguished road
You might be hitting the maximum local or global cells value. In that case snappy immediately stops refinement. Also falling under minRefinementCells can cause this. I usually use 1 here, so it refines until everything I want refined is refined.
AtoHM is offline   Reply With Quote
Old   December 3, 2024, 09:33
Leonardo Biscaino
Unfortunatelly, It didn't work :/ I put minRefinementCells = 1 and maximum local and global cells value = 200000, 2000000.
castellated, snappy hex mesh
Shape optimizing the tunnel case with energy on zyao1 FLUENT 0 December 1, 2020 16:05
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
CFD Post - How to check for case in an expression pilakin ANSYS 0 September 26, 2014 05:44
Modeling the flow in a fully axisymmetric case %e2%80%93 results with no peripheral symmetry evgenia OpenFOAM Running, Solving & CFD 0 February 14, 2008 11:23
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
