problem finding bad faces from outside mesher |
Yesterday, 13:50 |
Alan w
Rep Power: 6 |
Hi Folks,
After using an outside meshing tool, I brought the polyMesh folder into openFoam. Then, checkMesh said there was an error with some wrongOrientedFaces. Now, I'm trying to visualize those faces with surfaceSubset. According to help, the usage for this command is: surfaceSubset [OPTIONS] <surface file> <output surface file> <surfaceSubsetDict I could specify the <output surface file> as an stl file, but I am puzzled about the input <surface file>, since it did not originate with an stl file. This would be specified in the system/surfaceSubsetDict file, which I currently have as: Code:
FoamFile { version 2.0; format ascii; class dictionary; object surfaceSubsetDict; } faces #include "~/cfdaero/civic-bodyonly/constant/polyMesh"; localPoints (); edges (); zone (); addFaceNeighbours no; invertSelection false; Code:
--> FOAM FATAL IO ERROR: Istream not OK for reading dictionary file: surfaceSubsetDict at line 1. |
Yesterday, 13:53 |
Alan w
Rep Power: 6 |
Forgot to check my post before submitting! I meant to show the command I am using:
surfaceSubset wrongOrientedFaces wrongfaces.stl surfaceSubsetDict But of course this is wrong. |
Yesterday, 14:57 |
Alan w
Rep Power: 6 |
Found a solution to my problem in this thread:
Visualizing checkMesh results in Paraview |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[snappyHexMesh] [checkMesh] Highly skew faces detected after snappyHexMesh during checkMesh | Vignesh Veeresparan | OpenFOAM Meshing & Mesh Conversion | 1 | March 9, 2020 00:24 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
