November 28, 2024, 22:07 |
CFL number (Accuracy + computational time)
Hello everyone,
I am working on gas turbine combustion simulation (non-reacting flow for now). After grid independent test, my cell numbers are close to 8Million. If CFL is fixed as 0.3 or 0.5, delT becomes 2E-7 [s] for hexahedral mesh and 2E-8 [s] for polyhedral mesh, which consumes more computational time (due to lack of computational resource) to reach the converged solution at t = 0.5 [s] . Compromising the accuracy, I don't like fix the delT close to 1E-6 or lesser than that. However, I am in a situation to get my results as soon as possible. Is there any other way to handle this situation? Kindly share your thought please. Thank you Last edited by Kummi; November 28, 2024 at 22:10. Reason: Uploading images |
November 29, 2024, 07:05 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
If you are interested to a steady state just use an implicit scheme. |
accuracy, cfl, computationaltime |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 6, 2023 00:48 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 09:14 |
