TimeStep Error with SimFlow
Old   November 28, 2024, 18:54
Default TimeStep Error with SimFlow
Ojas Shastri
o100 is on a distinguished road
I'm using the free version of SimFlow, version 5.0, for a CFD simulation as part of a project to design and test an underwater navigation system for an autonomous ROV, and I’ve run into an issue where only the last two timesteps are being recorded. The simulation itself seems to be running fine, but when I check the output files, I only see the data for the last two timesteps instead of the entire simulation history.
I'm using Ubuntu 24.04.1 the SIMPLE Solver, at 10 second intervals, for 100 seconds.
I’ve already tried adjusting the output frequency in the Control Dict file, ensuring that the disk has sufficient storage space, and checking if the software is set to overwrite files instead of saving all timesteps.
Despite this, the problem persists.
Thanks in advance for any guidance!
File Type: png Screenshot from 2024-11-28 14-50-34.png (109.3 KB, 4 views)
o100 is offline   Reply With Quote
simflow, timestep error
Interpolate solutions from a fine mesh to a coarse mesh for every timestep Rekafeliz12 FLUENT 0 February 8, 2023 15:05
Adjustable timestep for settleling, then fixed timestep large eddy simulation stud-many OpenFOAM 1 June 16, 2021 00:09
Cfx initial time choice for adaptive timestep butterflymuzzy CFX 7 April 22, 2021 20:05
error with smaller timestep ? Thomas MADELEINE FLUENT 0 August 8, 2016 14:02
simFlow release AnetaC OpenFOAM Announcements from Other Sources 7 October 6, 2013 15:41
