Uneven Particle Volume Fraction in Radial Direction for Sandblasting Simulation Using
Old   November 27, 2024, 10:27
Default Uneven Particle Volume Fraction in Radial Direction for Sandblasting Simulation Using
Joseph
Kalindu115 is on a distinguished road
I am conducting a CFD simulation for a sandblasting case through a converging-diverging nozzle. I am using the Discrete Phase Model (DPM) in ANSYS Fluent to inject particles at the nozzle inlet. My objective is to achieve a uniform particle distribution in the radial direction at the inlet.
Here’s what I observed:
Particle Pathlines: The pathlines of the particles, as shown in the attached figures, indicate an even distribution in the radial direction.
Volume Fraction: When analyzing the particle volume fraction in the radial direction at the inlet, there is a higher concentration of particles near the axis and a lower concentration near the nozzle wall.
Particle Count: On examining the number of particles in the cells along the radial direction, it appears that the particles are almost evenly distributed.
Given this discrepancy between the volume fraction and particle count:
What could be the reason for this issue?
Is there an alternative method to calculate the volume fraction of particles in the radial direction (y-direction)?
Any insights or suggestions would be greatly appreciated.
Thank you!
Kalindu115 is offline   Reply With Quote
cfd, dpm, nozzle, particle
Limiting volume fraction in interFoam sita OpenFOAM Running, Solving & CFD 7 June 5, 2024 12:58
multiphaseEulerFoam FOAM FATAL IO ERROR qutadah.r OpenFOAM Running, Solving & CFD 11 December 10, 2021 21:18
Simulation crashes when turbulence is on (reactingMultiphaseEulerFoam) remidemol OpenFOAM Running, Solving & CFD 3 May 26, 2020 06:47
