Openfoam chtMultiRegionSimpleFoam Starting Issue - Help Needed
Old   November 23, 2024, 17:47
Default Openfoam chtMultiRegionSimpleFoam Starting Issue - Help Needed
Ned Lyon
OldUnixGuy49 is on a distinguished road
I am modeling a large piece of hot equipment that will be mounted above a roof to determine temperatures at roofing and waterproofing membranes. I've used Openfoam a little previously, but I'm not expert. I've researched the error I'm having and resolved several problems on my own including having too large a model for my computer. My mesh seems to be fine now, and solution progresses up to Time = 1 where it crashes as follows:
multiRegion multiRegion:
Spawned additional object(s):
multiRegion:Air1
multiRegion:Air2
multiRegion:Air3
multiRegion:Concrete1
multiRegion:Concrete2
multiRegion:Insulation1
multiRegion:Insulation2
multiRegion:Insulation3
multiRegion:Insulation4
multiRegion:Steel1
multiRegion:Steel2
Time = 1
Solving for fluid region Air1
#0 Foam::error:rintStack(Foam::Ostream&) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#1 Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#2 ? in /lib/x86_64-linux-gnu/libc.so.6
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#4 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so
#5 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so
#6 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so
#7 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so
#8 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so
#9 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam
#10 ? in /lib/x86_64-linux-gnu/libc.so.6
#11 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#12 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam
Floating point exception (core dumped)
I assume this is trying to tell me that some starting value I have is zero and causing a divide by zero error. Further the problem is in TurbulenceModels for Air1, though it may exist elsewhere. I'm currently using laminar in turbulenceProperties, but will likely need to change that if I need to simulate forced air circulation.
I would appreciate any guidance on which inputs to review/modify to get past this roadblock. Here is my changeDictionary for Air1 if that will help:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Website: https://openfoam.org |
| \ / A nd | Version: v2212 & Ned-Foam 2.0 November 2024 |
| \/ M anipulation | Source: AirSpaceCFD02-01
FoamFile
version 2.0;
format ascii;
class dictionary;
object changeDictionaryDict;
U
internalField uniform (0 0 0);
boundaryField
min-Y
type calculated;
value uniform (0 0 0);
max-Y
type calculated;
min-X
type calculated;
max-X
type calculated;
Air1_to_Steel1
type calculated;
Air1_to_Concrete1
type calculated;
Air1_to_Steel2
type calculated;
Air1_to_Insulation2
type calculated;
Air1_to_Insulation1
type calculated;
Air1_to_Insulation3
type calculated;
T
internalField uniform 322.04;
boundaryField
min-Y
type calculated;
value uniform 322.04;
max-Y
type calculated;
min-X
type calculated;
max-X
type calculated;
Air1_to_Steel1
type calculated;
Air1_to_Concrete1
type calculated;
Air1_to_Steel2
type calculated;
Air1_to_Insulation2
type calculated;
Air1_to_Insulation1
type calculated;
Air1_to_Insulation3
type calculated;
epsilon
internalField uniform 0.01;
boundaryField
min-Y
type calculated;
value uniform 0.01;
max-Y
type calculated;
value uniform 0.01;
min-X
type calculated;
value uniform 0.01;
max-X
type calculated;
value uniform 0.01;
Air1_to_Steel1
type calculated;
value uniform 0;
Air1_to_Concrete1
type calculated;
value uniform 0;
Air1_to_Steel2
type calculated;
value uniform 0;
Air1_to_Insulation2
type calculated;
value uniform 0;
Air1_to_Insulation1
type calculated;
value uniform 0;
Air1_to_Insulation3
type calculated;
value uniform 0;
k
internalField uniform 0.1;
boundaryField
min-Y
type calculated;
value uniform 0.1;
max-Y
type calculated;
value uniform 0.1;
min-X
type calculated;
value uniform 0.1;
max-X
type calculated;
value uniform 0.1;
Air1_to_Steel1
type calculated;
value uniform 0;
Air1_to_Concrete1
type calculated;
value uniform 0;
Air1_to_Steel2
type calculated;
value uniform 0;
Air1_to_Insulation2
type calculated;
value uniform 0;
Air1_to_Insulation1
type calculated;
value uniform 0;
Air1_to_Insulation3
type calculated;
value uniform 0;
p_rgh
internalField uniform 101325;
boundaryField
min-Y
type calculated;
value uniform 101325;
max-Y
type calculated;
min-X
type calculated;
max-X
type calculated;
Air1_to_Steel1
type calculated;
Air1_to_Concrete1
type calculated;
Air1_to_Steel2
type calculated;
Air1_to_Insulation2
type calculated;
Air1_to_Insulation1
type calculated;
Air1_to_Insulation3
type calculated;
p
boundaryField
min-Y
type calculated;
value uniform 0;
max-Y
type calculated;
value uniform 0;
min-X
type calculated;
value uniform 0;
max-X
type calculated;
value uniform 0;
Air1_to_Steel1
type calculated;
value uniform 0;
Air1_to_Concrete1
type calculated;
value uniform 0;
Air1_to_Steel2
type calculated;
value uniform 0;
Air1_to_Insulation2
type calculated;
value uniform 0;
Air1_to_Insulation1
type calculated;
value uniform 0;
Air1_to_Insulation3
type calculated;
value uniform 0;
qr
internalField uniform 0;
boundaryField
min-Y
type calculated;
value uniform 0;
max-Y
type calculated;
value uniform 0;
min-X
type calculated;
value uniform 0;
max-X
type calculated;
value uniform 0;
Air1_to_Steel1
type calculated;
value uniform 0;
Air1_to_Concrete1
type calculated;
value uniform 0;
Air1_to_Steel2
type calculated;
value uniform 0;
Air1_to_Insulation2
type calculated;
value uniform 0;
Air1_to_Insulation1
type calculated;
value uniform 0;
Air1_to_Insulation3
type calculated;
value uniform 0;
G
boundaryField
min-Y
type calculated;
value uniform 0;
max-Y
type calculated;
value uniform 0;
min-X
type calculated;
value uniform 0;
max-X
type calculated;
value uniform 0;
Air1_to_Steel1
type calculated;
value uniform 0;
Air1_to_Concrete1
type calculated;
value uniform 0;
Air1_to_Steel2
type calculated;
value uniform 0;
Air1_to_Insulation2
type calculated;
value uniform 0;
Air1_to_Insulation1
type calculated;
value uniform 0;
Air1_to_Insulation3
type calculated;
value uniform 0;
IDefault
boundaryField
min-Y
type calculated;
value uniform 0;
max-Y
type calculated;
value uniform 0;
min-X
type calculated;
value uniform 0;
max-X
type calculated;
value uniform 0;
Air1_to_Steel1
type calculated;
value uniform 0;
Air1_to_Concrete1
type calculated;
value uniform 0;
Air1_to_Steel2
type calculated;
value uniform 0;
Air1_to_Insulation2
type calculated;
value uniform 0;
Air1_to_Insulation1
type calculated;
value uniform 0;
Air1_to_Insulation3
type calculated;
value uniform 0;
alphat
boundaryField
min-Y
type zeroGradient;
max-Y
type zeroGradient;
min-X
type zeroGradient;
max-X
type zeroGradient;
Air1_to_Steel1
type compressible::alphatWallFunction;
Prt 0.85;
value uniform 0;
Air1_to_Concrete1
Prt 0.85;
value uniform 0;
Air1_to_Steel2
Prt 0.85;
value uniform 0;
Air1_to_Insulation2
Prt 0.85;
value uniform 0;
Air1_to_Insulation1
Prt 0.85;
value uniform 0;
Air1_to_Insulation3
Prt 0.85;
value uniform 0;
nut
boundaryField
min-Y
type calculated;
value uniform 0;
max-Y
type calculated;
value uniform 0;
min-X
type calculated;
value uniform 0;
max-X
type calculated;
value uniform 0;
Air1_to_Steel1
type nutUSpaldingWallFunction;
value uniform 0;
Air1_to_Concrete1
value uniform 0;
Air1_to_Steel2
value uniform 0;
Air1_to_Insulation2
value uniform 0;
Air1_to_Insulation1
value uniform 0;
Air1_to_Insulation3
value uniform 0;
Thanks in advance.
OldUnixGuy49 is offline   Reply With Quote
Old   December 2, 2024, 09:52
Default Multiple Issues
Ned Lyon
After a great deal of trial and error I was able to get this model off the ground. Basic issues were not having boundaries setup correctly and needing mappedPatch types for internal surface intersections. The model now runs but has other issues which I will address in a separate post.
chtmultiregionsimplefoam, crash at time = 1, thermodynamic model
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
PANS Turbulence Model Compilation Issue - OpenFOAM v-11 Ishak.Mazing OpenFOAM Programming & Development 0 December 6, 2023 11:30
Starting point for OpenFOAM yesaswi92 OpenFOAM 2 January 16, 2014 12:20
OpenFOAM Case Setup Needed mpl CFD Freelancers 4 October 10, 2013 17:14
Issue installation OpenFOAM - libopen-rte.so.0 Voyage_gui OpenFOAM 1 August 12, 2011 04:46
