Flow around flettner rotor and Magnus effect capture |
November 13, 2024, 06:37 |
Stefanos Manios
Rep Power: 3 |
Good day,
I set up a domain with a Flettner rotor to calculate Lift, drag, and relative CL-CD for specific Re / SR / Y+. The set-up trials include A) 1 region B) 2 regions (static-rotating) C) 2 regions with overset mesh The rotation simulated with: 1) MRF. 2) Sliding mesh. 3) Tangential velocity specification on the rotor boundary. Only the 3rd option provided reasonable results and pressure distribution around the cylinder however the deviation from the literature results in terms of Lift and Drag is significant. I would like to know if the specific effect needs a different approach to be captured. You are more than welcome to share your thoughts. I really appreciate any help you can provide. |
flettner rotor, magnus effect, star ccm+ |
