Std dev and variance in an unsteady simulation
Old   November 11, 2024, 06:57
Default Std dev and variance in an unsteady simulation
cons013 is on a distinguished road
Hello there,
I am investigating ways of speeding up an unsteady run but without compromising too much on accuracy. The current settings I am using seem to be very promising, and I was using the standard deviation and variance of the data set (in this case, for lift and drag values) to help drive any decision.
One of the ways I sped up the simulations was increasing the timestep and implementing less relaxation, among some other settings. I found that one configuration resulted in a lower std. dev and variance of the lift values than the benchmark case (currently used settings in our workflow).
What I want to know is, is this a useful metric at all? I worry that by using a larger time step, there may be some smaller scale flow effects that are smoothed/destroyed, which falsely improves these metrics. Any other valuable ways of judging the quality of an unsteady sim would be much appreciated!
cons013 is offline   Reply With Quote
Old   November 11, 2024, 08:22
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by cons013 View Post
Hello there,
Without full details is impossible to answer. Formulation, accuracy order, grid size and so on …
FMDenaro is offline   Reply With Quote
Old   November 11, 2024, 11:37
This is using the GEKO-based SBES solver in fluent, with bounded CD discretisation. The grid size is on the order of 1e8 with a timestep of the order 1e-4. I can't give many more details due to NDA, but hopefully that can help you get an idea.
Old   November 11, 2024, 13:12
Time-step in RANS formulation has no real physical meaning owing to the statistical solution. Time accuracy is not an real issue.
More relevant are some specific parameters in GEKO formulation as detailed here
https://www.ansys.com/content/dam/am...-Ansys-CFD.pdf
