How to control undulating vortex rope?
Old   October 23, 2024, 02:20
Question How to control undulating vortex rope?
Alexander Ohm
AlexanderOhm is on a distinguished road
Crystals in Las Vegas has an art installation by the shops that consists of a group of transparent water filled columns. Each sports a vortex that twist and turn, undulate and transition from thin stable vortex rope to misty chaotic whirlpool.
How do you think the water is controlled to achieve that?
AlexanderOhm is offline   Reply With Quote
Old   October 23, 2024, 05:55
Lucky
It's a column vortex which has an analytical solution. Grashof number tells when it transitions to unstable condition.
FYI You can see this type of vortex every morning if you fill a sink with water and then drain it. The difference is, the plughole vortex in your sink has a fixed dP due to gravity and you get whatever you see. But if you install a little gas pump device, then you can freely alter the rate of gas entrainment and actively control the shape of the vortex. It probably takes forever to do the CFD but an instant Amazon purchase will let you experience such an effect and see the action in real time.
It's also a common demonstration to children where you connect two 2L soda bottles, fill it with water, and then flip it upside down and watch the vortex form.
multiphase, vortex creation, water + air
LES of vortex rope in the elbow draft tube Sergeyevichsky CFX 4 March 24, 2017 05:50
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
How to control the display parts of ISO-surface of vortex region ? wyungh Tecplot 1 April 6, 2015 11:29
Presenation of vortex strength and velocity concept? fruitkiwi Main CFD Forum 0 September 26, 2012 23:08
vortex cause pressure gradient or pressure gradient induce vortex? fruitkiwi Main CFD Forum 4 June 12, 2012 02:12
