having issue with monitoring flowrate of water using interIsoFoam solver |
October 17, 2024, 09:00 |
sridhar
Rep Power: 2 |
| ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2406 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _be01ca78-20240625 OPENFOAM=2406 version=v2406 Arch : "LSB;label=32;scalar=64" Exec : interIsoFoam Date : Oct 17 2024 Time : 17:26:18 Host : NCILPT04 PID : 624475 I/O : uncollated Case : /home/sridhar/snappyAMI/cubeMetalFilling/demonf nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh staticFvMesh PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes Reading g Reading hRef Calculating field g.h No MRF models present No finite volume options present Selecting reconstructionScheme: isoAlpha DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop --> FOAM FATAL IO ERROR: (openfoam-2406) file: system/controlDict/functions/flowRate at line 60 to 66. From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType:ption, Foam::IOobjectOption::readOption) const [with T = bool] in file ./src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 327. FOAM exiting functions { flowRate { type surfaceFieldValue; libs (fieldFunctionObjects); field phi; surfaces (inlet); // Use surfaces instead of patches operation sum; writeControl timeStep; writeInterval 1; } } using openFoam-dev 2406 |
flowrate, interisofoam, liquid flow, multiphase |
Divergence detected in AMG solver | Rahmani_Zakaria | Fluent Multiphase | 4 | January 11, 2023 16:09 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 06:02 |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 05:03 |
twoPhaseEulerFoam confined plunging jet simulation failed | ves | OpenFOAM Running, Solving & CFD | 2 | June 17, 2020 06:08 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 15:27 |
