keep process running
Old   September 8, 2000, 11:03
Default keep process running
Jian Xia
Dear friends,
We are using SGI ORIGIN 2000 system. I tried to keep a process xj(a fortran excute file) running after I logged out. So I typed command: "nohup xj", then logged out. But the process xj stopped at the sametime I logged out. Could any one help me? Thanks.
Old   September 8, 2000, 11:12
Default Re: keep process running
Bart Prast
do this: type xj then type CTRL-z (puts the process on hold) then type bg (puts the process in the background) then logout
make sure the program doesn't send any information to the screen as it will stop while trying to do so
Old   September 8, 2000, 11:29
Zhengtong Xie
An easy way: xj>temp & ; that means put your screen message to temp, and run the code in the background. Then you could logout.
Good luck
Old   September 8, 2000, 11:49
Mark Olesen
This likely a shell problem. I've experience the same with the SunOS 5.7 ksh, but have had no problems with our SGI's ksh.
"foocmd &" *should* work without difficulties on (t)csh since SIGHUP is caught by cshell.
"nohup foocmd&" or "nohup foocmd > /dev/null&" is required by ksh, since SIGHUP may not be properly (mostly never) caught by ksh
Thus nohup will ALWAYS work, sometimes. For a fully bulletproof backgrounded cmd use 'at' instead: "at -f foocmd.script" now
This also keeps your mailer busy and out of trouble.
cheers, ------------------------------------------------------ Dr. Mark Olesen ZEUNA STAERKER GmbH & Co. KG Biberbachstr. 9 tel: +49 / 821 / 4103-862 D-86154 Augsburg, GERMANY ------------------------------------------------------
Old   September 8, 2000, 14:18
kakollu
nohup is the right the way to do it, may u should check the man pages for nohup. cox
Old   September 8, 2000, 21:50
Jian Xia
thanks
Almost have my cluster running openfoam, but not quite... bjr OpenFOAM Running, Solving & CFD 17 March 6, 2020 10:52
Cyclic BC with parallel running rdrr84 OpenFOAM Running, Solving & CFD 2 September 30, 2011 06:43
[PyFoam] Running multiple instances of solver using MPI and PyFoam bfa OpenFOAM Community Contributions 3 January 25, 2011 18:57
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
Process Editor shows no running jobs tchavdarov OpenFOAM Pre-Processing 1 March 9, 2005 04:43
