Boundary conditions
Old   October 3, 2024, 07:02
Default Boundary conditions
Matthew
hunt_mat is on a distinguished road
How good are interpolating polynomials in CFD?
I'm working on a finite volume code, and I need to find the value of the density on the boundary and I only have the midpoint values. I thought about using the first three mid-point values to obtain a quadratic equation rho(x)=ax^2+bx+c, and then set x=0 to obtain the value at the boundary.
Does this sound reasonable?
hunt_mat is offline   Reply With Quote
Old   October 3, 2024, 08:09
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
But that would be an extrapolation…
I used to compute the value on a fiinite volume surrounding the node on the boundary.
FMDenaro is offline   Reply With Quote
Old   October 3, 2024, 17:11
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I would start from what you know on the boundary. If density is involved in your calculation (i.e., it isn't constant), and you don't already know it in a point, I expect you to know some other variable from which density can be desumed, like pressure and temperature.
Unless you are actually working out how to apply your boundary conditions in the first place... in that case, as mentioned by Filippo, do not extrapolate at higher order, ever. In FV codes, if some variable needs to be extrapolated, it is typically copied from the nearest cell center. But it depends from which boundary condition you are working on and the kind of code.
You need to tell more (kind of code, kind of bc, additional details on the boundary and scope of the task, etc.) in order to have a sharper suggestion.
sbaffini is offline   Reply With Quote
Old   October 9, 2024, 12:29
Matthew
This doesn't actually tell be anything. I've tried that method before, and it failed.
Old   October 9, 2024, 12:34
Describe the way you tried. I built a volume surrounding the node on the wall and computed the fluxes on the faces in the flow interior (no mass flux on the wall, of course)-
Old   October 9, 2024, 12:38
Matthew
I assume you're referring to some kind of constitutive equation, like an ideal gas. I don't have that unfortunately.
I've heard this from someone, can you tell me why?
I'm solving the set of PDEs:
v_t=u_h, u_t=(P_L(v)+zeta(v)/v*u_h)_h
Where v is specific volume and h denotes the amount of mass from x=0. I have stress-free conditions a P_L(v) and zeta(v) are functions of v.
Old   October 9, 2024, 12:41
Matthew
This is the method I used.
Old   October 9, 2024, 12:45
If I understand, you can write Eq.(8) on the boundary and solve it
Old   October 10, 2024, 05:27
Matthew
I need to find the u_i on the cell interfaces. That implies I need to find them on the boundary. I thought that the extrapolation I did provided the appropriate extrapolation, or so I thought.
Old   October 11, 2024, 10:46
sbaffini's Avatar
Paolo Lampitella
I am not accustomed to this kind of problem but, I can only notice that:
1) You don't actually need a bc on v, you need v on the boundary because it is needed by the bc on u. Indeed, the volume integrated equation for v only has u as flux terms. If you have u on boundaries you can evolve v in any cell, it seems to me. Is this interpretation correct?
2) I know nothing about sintering, but not having a bc is weird. I would look better at some literature on the matter to find out how bcs are applied here.
3) In any case, if there isn't a bc, extrapolating the nearest cell value is just as good as using the second order interpolation, but it has the added benefit of not introducing any new maxima or minima. Introducing new maxima or minima trough bcs is an almost certain way to divergence (altough, there might be cases where this doesn't happen).
Old   October 11, 2024, 12:55
Matthew
The boundary condition for u on the boundary comes in the form of a Neumann condition, so you have du/dh on the boundary, this I used for the boundary conditions to get the u on the boundary from the stress free condition. This requires the information on v on the boundary
I have no idea what the boundary condition might be. All I know is that the total mass remains the same. I'm not sure what to use as a boundary condition. I could say that the mass flux through the boundary is zero, that will lead to dv/dh=0 on each boundary.
So I don't need to use my approach by fitting a quadratic?
finite volume method
reverse flow in centrifugal fan blades kalm CFX 20 December 2, 2023 07:25
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
