Need help in running the CONTUR code of Sivell |
October 3, 2024, 04:09 |
Rep Power: 2 |
Dear all,
I am trying to design a Mach 2 planar nozzle using CONTUR by Sivell which can be found here https://github.com/noahess/conturpy The code does not run with the input values I have provided. Any help on this matter is appreciated. I have attached a screenshot of my input values(cards) Thank you in advance! Code:
c = ConturSettings() dmach = 2.0 # design mach throat_radius = 2/2#2 / 2 # inches # Card 1: the title of the simulation c["ITLE"] = f"Mach {dmach}" c["JD"] = -1 # Card 2 contains gas properties. As air is the assumed working fluid, no changes are required c["ZO"] = 1 c["RO"] = 1 c["VISC"] = 1 c["VISM"] = 1 c["SFOA"] = 0 # Card 3: key design parameters c["ETAD"] = 6.5949402 # Angle at point D c["RC"] =2.0 # Radius of curvature at throat [multiple of throat radius] #c["FMACH"] = 1.26 c["BMACH"] = 1.5 c["CMC"] = dmach # Design mach c["SF"] = 0 # Card 4: #c["IX"] = 1 c["ND"] = 15 c["MP"] = 5#1 c["MQ"] = 0#41 c["JB"] = -1 c["JC"] = 0 c["IT"] = 0 c["LR"] = 21 # Card 6 (B): stagnation and heat transfer properties c["PPQ"] = 120 # Stagnation pressure [psia] c["TO"] = 1000 # Stagnation temperature [R] c["TWT"] = 540 # Wall temperature [R] c["TWAT"] = 540 # Water-cooling temp [R] (suggest setting to TWT since water cooling not assumed) # Card 7 (D): interpolation parameters c["XLOW"] = 0 # Point to begin interpolating contour [in] c["XEND"] = 0.7 # Point to end interpolating contour [in] c["XINC"] = .1 # Increment to interpolate by [in] # Create the input text file and save it to 'm5.0.txt' in the folder 'inputcards' c.print_to_input(file_name=f'm{dmach:.1f}.txt', output_directory='inputcards') |
cd nozzle, fortran 90, method of characteristics, python, sivells nozzle design moc |
'Signal: Segmentation fault (11)' while running openFoam in Parallel Processing | jaymeen721 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2023 20:17 |
How to allow MPI code run in serial mode with a single CPU core? | aerosayan | Main CFD Forum | 15 | May 30, 2022 14:05 |
Running OpenFOAM using a C++ master code | salehi144 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2014 05:14 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 16:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 09:10 |
