Dispersion of the source term in Schnerr and Sauer cavitation Model
Old   September 13, 2024, 09:48
Post Dispersion of the source term in Schnerr and Sauer cavitation Model
shamiaoluo
BUAA LSM is on a distinguished road
In the cavitation Model, the mass transfer of liquid phase and vapor phase has been calculated by the cavitation model. Taking the evaporation process as an example, in Figure 1, equation 1 is the phase fraction equation, and Schnerr and Sauer Model have given the expression of the source term, as shown in equation 2.
Now there are two discrete methods, the first is explicit processing, as shown in Figure 2, but the results of the calculation do not seem to be quite correct.
The second Method is The Finite Volume Method in Computational Fluid Dynamics, as shown in Figure 3, but it is difficult to differentiate the source term, because both the mixing density and the bubble radius are related to the phase fraction,as shown in equations 3 and 4. Is there a good way to do the volume integration of the source term?
BUAA LSM is offline   Reply With Quote
Old   September 19, 2024, 11:37
Troy Snyder
tas38 is on a distinguished road
Your question relates to the linearization of the source term, i.e. its explicit vs. implicit treatment.
Regarding your explicit treatment (Figure 2), I am not sure what you mean by the results of the calculation do not seem to be quite correct. Are you referring to the particular form of the fully explicit source term treatment or converged simulation results?
If no errors were made in the derivation, and the simulation converges, then the explicit treatment of the source term should work fine. The introduction of some degree of "implicitness" in the source term formulation is typically needed to aid in convergence, but the source term treatment should not impact the converged result unless an error was made in its derivation.
tas38 is offline   Reply With Quote
cavitation, dispersion, schnerr and sauer model, source term
Schnerr Sauer 2001 paper tas38 Main CFD Forum 1 March 5, 2015 06:13
Bubble Radius in Schnerr Sauer cavitation model (mistake?) zarox OpenFOAM Running, Solving & CFD 12 September 24, 2014 09:05
Convergence Problem with Cavitation Model I-mech FLUENT 1 June 19, 2014 15:22
