About compressible and incomprehensible flow
Old   September 13, 2024, 04:04
Default About compressible and incomprehensible flow
Haidong Lu
Diele is on a distinguished road
Hey guys,
A laser beam acts on the surface of a spherical liquid droplet to produce plasma, and the droplet is deformed and moves in the opposite direction of the laser incident. It has been pointed out in the literature that the dropper deformation after the laser action is an incompressible flow. Can our existing compressible flow code be used to deal with this incompressible flow?
Diele is offline   Reply With Quote
Old   September 13, 2024, 08:31
Cas
CornelisLely is on a distinguished road
"incomprehensible flow" haha thats a good description
Yes you can change your code to make the density of the fluid only dependent on temperature, instead of being dependent on pressure and temperature. Practically, this will make your flow incompressible or incomprehensive as you say
CornelisLely is offline   Reply With Quote
Old   September 13, 2024, 09:52
Lucky
The "literature" is simply wrong. All flows are compressible. Incompressible flows violate Einstein's special theory of relativity. There is no reason to force a compressible code to act like an incompressible storyboard for the sake of matching someone else's wrong conclusion.
Old   October 5, 2024, 06:32
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Originally Posted by Diele View Post
Hey guys,
Physics says that all the materials, especially fluids, are compressible to a certain extent. Numerics doesn't really like that, because of the implications on the time scales.
But, physics apart, all the modern codes now have the capability to run in a mixed way (some zone incompressible, some others not) starting from a fully compressible formulation. In the same way, a modern fully compressible code has the capability to run fully incompressible.
Take home messages:
1) learn about the capabilities of modern CFD codes and how they work in different compressibility scenarios
2) forget about the numerics and focus on your actual physics, which can be probably handled by a modern CFD code
sbaffini is offline   Reply With Quote
compressible flow, incompressible flow
About compressible and incomprehensible flow granzer Main CFD Forum 8 September 13, 2019 04:52
Reversed Flow in Outlet Steve FLUENT 18 March 30, 2013 08:50
