How to compute Pression Diffusion term of TKE Budget in MATLAB?
Old   September 11, 2024, 04:47
Default How to compute Pression Diffusion term of TKE Budget in MATLAB?
Samoza is on a distinguished road
Hello everyone,
I'm doing my first "numerical analysis" in turbulence and I'm trying to plot all the terms of the TKE (Turbulent Kinetic Energy) Budget in a single graph to compare the curves with the data obtained by Moser, Kim, and Mansour (1999). The formula for the TKE Budget is shown in the attached image (TKE_eq (2).JPG).
The flow under consideration is a turbulent channel flow. I have successfully plotted almost all the terms (Production, Turbulence Diffusion, Viscous Diffusion, Dissipation rate), and the results align well with the data from Moser, Kim, and Mansour as you can see in the attached image (TKE Budget.png). However, I am having trouble correctly plotting the Pressure Diffusion term.
The available data includes:
  • Three 3D matrices (256x128x128) named u_prime, v_prime, and w_prime, representing the fluctuations of the velocity components along the x, y, and z directions, respectively.
  • A 3D matrix p_prime (256x128x128) representing the pressure field.
  • Three 3D matrices x, y, and z (256x128x128) representing the spatial coordinates.
The data from Moser, Kim, and Mansour can be accessed at the following website: https://turbulence.oden.utexas.edu/MKM_1999.html. The specific file containing the data for comparison is located at chan180/balances/chan180.kbal.
In the file chan180.kbal, it states “Normalization: U_tau, nu/U_tau,” and the numerical method adopted is also mentioned: “Kim, Moin & Moser, 1987, J. Fluid Mech. vol 177, 133-166,” which can be viewed at the link http://www.oroussel.free.fr/articles/KMM87.pdf.
Given that the formula for Pressure Diffusion is shown in the image, labeled as uppercase pi, how would you write the code to correctly plot the Pressure Diffusion term?
Here is my attempt:
clc;
clear;
close all;
% Space Statistics
% Importing cells centers coordinates
ccx = importdata('ccx');
ccy = importdata('ccy');
ccz = importdata('ccz');
% Importing velocity field
filePath = 'U.gz';
tempDir = fullfile(tempdir, 'tempExtraction');
gunzip(filePath, tempDir);
U = importdata(fullfile(tempDir, 'U'));
% Importing pressure field
pField = importdata('p');
% Parameters
nx = 256;
ny = 128;
nz = 128;
delta = 1;
u_tau = 1;
nu = 1/180;
Re = (delta * u_tau) / nu;
rho = 1;
% Allocating values in matrices
u = zeros(nx, ny, nz);
v = zeros(nx, ny, nz);
w = zeros(nx, ny, nz);
x = zeros(nx, ny, nz);
y = zeros(nx, ny, nz);
z = zeros(nx, ny, nz);
p = zeros(nx, ny, nz);
index = 1;
for k = 1:nz
    for j = 1:ny
        for i = 1:nx
            u(i, j, k) = U(index, 1);
            v(i, j, k) = U(index, 2);
            w(i, j, k) = U(index, 3);
            x(i, j, k) = ccx(index);
            y(i, j, k) = ccy(index);
            z(i, j, k) = ccz(index);
            p(i, j, k) = pField(index);
            index = index + 1;
        end
    end
end
% Calculating mean profiles for every y
u_mean = mean(u, [1, 3]);
v_mean = mean(v, [1, 3]);
w_mean = mean(w, [1, 3]);
p_mean = mean(p, [1, 3]);
% Calculating fluctuations fields
u_prime = u - u_mean;
v_prime = v - v_mean;
w_prime = w - w_mean;
p_prime = p - p_mean;
% Extracting position vectors
x_direc = x(:, 1, 1);
y_direc = y(1, :, 1);
z_direc = z(1, 1, :);
% Calculating y_plus
y_plus = (y_direc * u_tau) / nu;
% Calculating differences along directions x, y, and z
dx = diff(x_direc);
dy = diff(y_direc);
dz = diff(z_direc);
% Importing Moser, Kim and Mansour data
fileID = fopen('chan180.kbal', 'r');
chan180kbal = textscan(fileID, '%f%f%f%f%f%f%f%f%f', 'CommentStyle', '#');
fclose(fileID);
y_plusMKM = chan180kbal{2};
pressDiffMKM = chan180kbal{6};
% Pressure diffusion term
mean_pu_prime = mean(p_prime .* u_prime, [1, 3]);
mean_pv_prime = mean(p_prime .* v_prime, [1, 3]);
mean_pw_prime = mean(p_prime .* w_prime, [1, 3]);
dpu_dx = diff(mean_pu_prime) ./ dx;
dpv_dy = diff(mean_pv_prime) ./ dy;
dpw_dz = diff(mean_pw_prime) ./ dz;
pressDiff_pre = -(1/rho) * (dpu_dx + dpv_dy + dpw_dz);
pressDiff_pre = pressDiff_pre(1, :, 1);
pressDiff = NaN(1, 128);
pressDiff(1:127) = pressDiff_pre;
% Plotting pressure diffusion terms
figure;
hold on;
plot(y_plus, pressDiff/Re, 'DisplayName', '$\Pi$');
plot(y_plusMKM, pressDiffMKM, '--', 'DisplayName', '$\Pi_{MKM}$');
xlabel('$y^+$', 'Interpreter', 'latex');
xlim([0 max(y_plusMKM)/2]);
plotTitle = 'Pressure Diffusion Term';
title(plotTitle, 'Interpreter', 'latex');
legend('show', 'Location', 'northeast', 'Interpreter', 'latex');
grid on;
box on;
hold off;
The output of this code is attached (PressDiffTerm.png). I will provide the files via WeTransfer if anyone wants to try performing the calculation: https://we.tl/t-3UWWWrHyo0
For any clarifications, please do not hesitate to ask, and I will do my best to respond.
Last edited by Samoza; September 13, 2024 at 04:47. Reason: mistake in the code, providing the data, clarification
Samoza is offline   Reply With Quote
Old   September 12, 2024, 17:14
Jack Sullivan
sulli72 is on a distinguished road
Hi Samoza,
Just wanted to ask some clarifying questions and leave some thoughts.
First question: Are these budgets being computed from one snapshot, that is averaged in the spanwise and streamwise directions?
if so, you might see better convergence in the pressure term if multiple snapshots are considered when computing the budgets.
Second question: How has pressure been non-dimensionalized in the original DNS code? You may need to carry this non-dimensionalization factor through the derivation of the pressure diffusion term, resulting in some factor that pre-multiples the derivative terms you compute numerically. I've run into this issue before when working with compressible TKE budgets, where lack of proper non-dimensional scaling can make certain profiles be off by orders of magnitude while others look ok.
Hope this helps, and happy budgeting!
sulli72 is offline   Reply With Quote
Old   September 12, 2024, 18:56
Originally Posted by sulli72 View Post
Hi Samoza,
Hi sulli72,
Here are my responses to your questions:
First response: I was provided with 22 snapshots of the turbulent flow, and I arbitrarily chose snapshot number 3. Since I didn’t encounter any issues when plotting the other TKE terms using a single snapshot, I thought that wasn’t the problem.
Second response: If by the original DNS code you mean the numerical method used by Moser et al., then unfortunately, I don't know how the pressure was non-dimensionalized. Or rather, I’m not entirely sure. In the file `chan180.kbal`, it states “Normalization: U_tau, nu/U_tau,” which, as written, isn't very clear to me. The numerical method adopted is also mentioned: “Kim, Moin & Moser, 1987, J. Fluid Mech. vol 177, 133-166,” which can be viewed at the link [http://www.oroussel.free.fr/articles/KMM87.pdf](http://www.oroussel.free.fr/articles/KMM87.pdf).
I hope I’ve answered your questions.
Old   September 12, 2024, 23:46
Lucky
dpv_dy = diff(mean_pu_prime) ./ dy;
dpw_dz = diff(mean_pu_prime) ./ dz;
should be
Old   September 13, 2024, 01:25
Christopher Adams
Christofer is on a distinguished road
Oh yeah, it's a bit of a pain when you manage to track down all but one term! It's often helped me out with stuff like this.
Christofer is offline   Reply With Quote
Old   September 13, 2024, 04:40
Originally Posted by LuckyTran View Post
should be
Oops, you're right. My bad, but still, in the plot, the two curves don't match. I will edit the original post.
matlab code, pressure diffusion, tke budget
Resolved TKE budget terms calculation from LES Simulations Agavi Main CFD Forum 11 June 2, 2021 17:13
calculating TKE budget in OpenFOAM foamUser2020 OpenFOAM Post-Processing 2 May 14, 2021 09:52
TKE budget dissipation in LES bala_gk1988 OpenFOAM Running, Solving & CFD 1 July 9, 2016 05:51
TKE budget estimation by k-epsilon model pd.iiest FLUENT 1 March 12, 2016 12:25
TKE budget equation in LES doctorWho Main CFD Forum 3 March 12, 2014 12:27
