September 3, 2024, 18:04 |
Overpredicted Lift coefficient
Dipankar Sarkar
Rep Power: 6 |
Currently, I am simulating flow over an airfoil 2D steady-state.
turbulence model: k-w sst Boundary condition: velocity inlet, pressure outlet, wall and airfoil solver: coupled chord: 1m density: 1.184 kg/m^3 viscosity: 1.85*10^-5 velocity: 15.625 m/s Reynolds number: ~ 1,000,000 I did the grid independence test and tried to validate the CFD results with the Experimental data. however, the CFD results (lift coefficient) are overshooting or overpredicted compared to the experimental data. 1/What could be the reason behind this? 2/ What would be the possible solution to fix this issue? for your reference, I am attaching the figures below. GIT.jpg Validation.jpg Note: in GIT plot the triangle markers are the lift coefficient data |
ans, grid convergence study, lift coefficent, validation |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 07:04 |
Oscillation in lift coefficient plot | hsuam | FLUENT | 0 | May 1, 2021 18:31 |
Lower Lift coefficient value | goutamp | FLUENT | 3 | December 12, 2020 17:31 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 06:18 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
