Mixed radiation+convection external wall BC in Code_Saturne
Old   August 30, 2024, 23:25
Post Mixed radiation+convection external wall BC in Code_Saturne
Theo Firelli
Engineers_Firelli is on a distinguished road
I'm new on the forum. I'm trying to simulate a hot gas flow through ducts in Code_Saturne. I was wondering how to setup a boundary condition that combines:
* a heat transfer coefficient + outer temperature (representing the convection between the external wall and the ambient)
* an emissivity at the outer wall + outer temperature (representing the radiation from the externall wall to the ambient)
(* perhaps it would be nice also to include the conduction in the wall, but this may be calculated analytically and included in the heat transfer coefficient mentioned above)
1. Using the GUI, I tried different combinations of BC for the temperature scalar and for the thermal radiative heat transfer (I included a P1 radiation model, although I don't want it for the fluid, I just want the radiation from the external wall of the duct to the ambient).
However, the "thermal radiative heat transfer" does not seem to have any effect on the temperature distribution on the wall (the wall does not cool down through radiation), although I tried different emissivities, ambient temperatures, even with a conductivity heat flow.
2. I thought of another idea, to use a user law to define the heat flux or the heat transfer coefficient (and for example use the trick h = h_conv + h_rad, where h_rad = sigma * epsilon * (T_wall^4 - T_ambient^4)/(T_wall - T_ambient) ). However, how can one access the temperature value on the wall patch from the user law definition in the GUI ?? It seems to be possible to access only time and space variables.
If this is only possible through the code, could someone please explain the details of how to do it using the code (how to access the temperature value on the patch and to define the heat flux or the heat transfer coefficient based on the temperature) ?
Thanks in advance.
Theo
Engineers_Firelli is offline   Reply With Quote
boundary condition, code saturne, heat transfer coefficient, radiation
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Difference between External and Internal flow radiation problems Kummi FLUENT 0 April 10, 2018 04:06
BC for Boltzmann radiation on external wall aeroMatze OpenFOAM Running, Solving & CFD 0 May 19, 2016 18:18
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 05:12
natural convection problem with radiation jorien CFX 0 October 14, 2011 10:26
