Q. regarding the derivation of Reynolds' Eq.
Old   August 30, 2024, 06:14
Default Q. regarding the derivation of Reynolds' Eq.
M.W
Yuhan
M.W is on a distinguished road
Hi everyone,
I am working on derivation of the Reynolds thin film theory, i got a question about the assumptions or simplify of the derivation process. I have been reading some literatrure about the derivation process and known it should start from integration of:
∂τ/∂z=∂P/∂x (i)
∂τ/∂z=∂P/∂y (ii)
(for clearly, the axis of the thin film thickness is z, the film is spreading in x&y, the velocitys are written as u,v,w respectively)
My dumb question is: how could we have these eq.?
I know the Reynolds's eq is a special form of N.S. eq, so I start from the N.S. eq in x&y-axis:(body force ρa_x&ρa_y is neglected)
ρDu/Dt=-∂P/∂x+∂τ_xx/∂x+∂τ_yx/∂y+∂τ_zx/∂z (iii)
ρDv/Dt=-∂P/∂y+∂τ_xy/∂x+∂τ_yy/∂y+∂τ_zy/∂z (iV)
If I want to have eq(i)and(ii) from eq(iii)and (iV), the following conclusions are made:
a) material derivative of velocity (LHS) equals 0;
b) ∂τ_xx/∂x=∂τ_yx/∂y=∂τ_xy/∂x=∂τ_yy/∂y=0;
∂τ_zx/∂z and ∂τ_zy/∂z are caused by the different velocity through z, which is comprehensible for me. I dont understand what assumptions or simplify are made to achieve the a) and b).
For example, the ∂τ_yx/∂y=0 means there is no shear stress applied on XZ surface of the fluid element, is that means the u is constent through the y-axis?
Hopefully someone could help me out, thank you in advance!
M.W is offline   Reply With Quote
Old   September 2, 2024, 12:26
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by M.W View Post
Hi everyone,
∂τ/∂z=∂P/∂x (i)
∂τ/∂z=∂P/∂y (ii)
Why did not you introduce the newtonian closure law and see the velocity gradients components?
FMDenaro is offline   Reply With Quote
Old   September 3, 2024, 21:00
Lucky
a) is the low Reynolds number assumption
b) is the thin film assumption. The film thickness in z is much smaller than the dimension in x and y.
Note that you don't formally equate these terms to zero, but order of magnitude analysis yields that they are much smaller than the remaining terms.
ns equation, reynolds equation, thin film theory
Derivation for Reynolds Number? arungovindneelan Main CFD Forum 25 January 4, 2020 08:18
Why are there different definitions for cell Reynolds number? carl jung Main CFD Forum 10 September 5, 2016 10:51
CFX Solver Reynolds Number haider760 CFX 2 March 4, 2012 23:05
Reynolds Stress Models Jade M Main CFD Forum 0 April 21, 2010 17:38
Derivation of reynolds equation Mark Harten Main CFD Forum 2 September 9, 1999 12:23
