How to reduce computational cost or time.
Old   August 26, 2024, 02:39
Default How to reduce computational cost or time.
cheap person
cheap_person is on a distinguished road
Hey Guys!
How are you doing?
Well, I've been designing an impeller,
Kindly consider me as a beginner throughout the conversation.
Now I am trying to generate a performance map {nominal mass flow rate v/s pressure ratio} of the impeller to know the operational range.
Hence, I need to Run multiple simulations, to generate points which leads to graph.
Whereas, I run a steady simulation for 3 hours with 1000 iterations and a transient simulation for one and a half hours with 200-time steps with 5 sub-iterations.
I cannot afford such high computational time. so how can I reduce it?
It would be warmly appreciated if any replies.
Sending positive vibes!
cheap person 😁
cheap_person is offline   Reply With Quote
Old   August 27, 2024, 02:54
SimulationLearner is on a distinguished road
Which model you are using to run the simulations?
SimulationLearner is offline   Reply With Quote
Old   August 27, 2024, 10:56
rocketLauncher is on a distinguished road
What tool and model are you using?
If you were to make use of open-source tools, you could run a parallel simulation on multiple cores (limited by your computer). You could even run multiple simulations in parallel.
To give you a real answer, you need to give us some more details about your case, the degree of accuracy that you need, your computational power resources etc.
Good luck
rocketLauncher is offline   Reply With Quote
Old   September 7, 2024, 02:50
eddienel98 is on a distinguished road
Originally Posted by cheap_person View Post
Hey Guys!
How are you doing?
Now I am trying to generate a performance map {nominal mass flow rate v/s pressure ratio} of the impeller to know the operational range. uno online
cheap person 😁
To reduce computational time, you can simplify your mesh in non-critical areas, reduce the number of iterations and time steps, or loosen convergence criteria for quicker results. Additionally, using parallel computing or starting with 2D simulations can help speed up the process.
eddienel98 is offline   Reply With Quote
ansys, cfd, computation time, turbo machinery
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Slow calculation time on CFD server killian153 Hardware 4 July 27, 2021 08:28
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
