August 24, 2024, 08:51 |
How to make performance map of an impeller
cheap person
Rep Power: 2 |
Hey Guys!
How are you doing? Well, I've been designing an impeller, Kindly consider me as a beginner throughout the conversation. Now I am trying to generate a performance map {nominal mass flow rate v/s pressure ratio} of the impeller to know the operational range. However, I've gone through the Ansys documentation & YouTube but found no tutorial. If there are already some tutorials, please provide me with any references. In case of unavailability, we can continue with the threat. But I don't have any clue how to start. It would be warmly appreciated if any replies. Sending positive vibes! cheap person 😁 |
August 24, 2024, 10:32 |
Lucky
Rep Power: 66 |
I recommend you to study the Ansys tutorials
August 25, 2024, 07:32 |
#3 | |
cheap person
Rep Power: 2 |
Thank you so much Lucky Tran for replying to me!! but I have some doubts: 1. I run the steady simulation for 3 hours with 1000 iterations and the transient simulation for one and a half hours with 200-time steps with 5 sub-iterations. I cannot afford such high computational costs. so how can I reduce it? 2. My input parameters is {speed} and output parameters are {pressure ratio, mass flow rate}, which is time dependent. If I am wrong anywhere, please correct me or if there is another method, please tell me. Sending positive vibes... Again! cheap person 😁 |
August 25, 2024, 18:35 |
Lucky
Rep Power: 66 |
Don't be cheap
I could tell you the secret to doing it cheaper but you have to subscribe to my video for $25 but you have to sign up in the next 60 seconds because I have limited offers and they're going fast. |
August 26, 2024, 01:55 |
#5 | |
cheap person
Rep Power: 2 |
Damn.. your pitching style... Demand and supply. Once a cheap always a cheap 🤣 cheap person |
ansys, cfx, performance curve, turbo machinery |
General recommendations for CFD hardware [WIP] | flotus1 | Hardware | 19 | June 23, 2024 19:02 |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 13:38 |
[blastFoam] BlastFoam Question | alimea | OpenFOAM Community Contributions | 17 | January 28, 2023 11:50 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
How to make good performance thermalcouples | ztdep | Main CFD Forum | 0 | August 16, 2006 07:16 |
