" ERROR #004100018, Fatal overflow in linear solver." In Transient CFD. |
August 13, 2024, 09:03 |
cheap person
Rep Power: 2 |
Transient CFD Analysis of Rotor and Stator | Time Transformation | Ansys CFX
Hi there, I'm trying to do a simulation of {impeller + diffuser}. no of blades in impeller, diffuser is 15 and 25 respectively. 1. The following image shows the Boundary conditions of the simulation: 2. The following image shows the basis setting of Transient blade row model of the simulation: but while processing the simulation it shows an error, as shown in Picture: Your efforts will be warmly appreciated. cheap person |
August 13, 2024, 11:28 |
Hamid Zoka
Rep Power: 18 |
divergence could be due to the large pressure difference i.e. from 1 to 5 bar. This huge presusre gradient can causae problem particularly at early iterations where flow field is not properly formed. You need a really good initial solution to tackle the issue. Also you can check convergence with lower pressure differences. Best |
August 13, 2024, 13:43 |
Arjun
Rep Power: 34 |
What he said.
Check if you have some potential flow based initialization. QUOTE=Hamidzoka;873366]Hi, divergence could be due to the large pressure difference i.e. from 1 to 5 bar. This huge presusre gradient can causae problem particularly at early iterations where flow field is not properly formed. You need a really good initial solution to tackle the issue. Also you can check convergence with lower pressure differences. Best[/QUOTE] |
cfd analysis, impeller, transient analysis, turbo machinery |
Fatal overflow in linear solver. | XIAJINXIA | CFX | 4 | March 7, 2024 09:30 |
Fatal Overflow in Linear solver. | Gokkul | CFX | 6 | March 8, 2022 19:54 |
Fatal overflow in linear solver | n.soumya | CFX | 2 | August 8, 2015 21:36 |
the problem of my transient simulation "Floating point exception: Overflow " | alloveyou | CFX | 15 | November 22, 2012 11:14 |
Fatal overflow in linear solver | James113 | CFX | 1 | June 2, 2012 06:29 |
