ViV 2-way FSI
Old   August 11, 2024, 10:01
Default ViV 2-way FSI
Eric Antonio Soares Silva
EricAntonio is on a distinguished road
I want to simulate a flow around a circular cylinder for vortex induced vibrations, I made a simulation in 2d using UDF to apply constrictions to the movement, two springs in xy directions attached to the cylinder. How can I make a similar case but in 2-way FSI using system coupling with transient structural and fluent? There are some structures attached to the cylinder too, can I use an UDF for the cylinder and 2-way FSI for the structures attached to the cylinder at the same time?
thanks in advance
EricAntonio is offline   Reply With Quote
fluent, fsi, fsi 2-way coupling, transient structural, viv
[FSI] Sudden divergence of elastic pipe FSI MFWilliams OpenFOAM CC Toolkits for Fluid-Structure Interaction 1 June 16, 2022 12:35
[solids4Foam] FSI case does not converge, foam extend 4.0 MFWilliams OpenFOAM CC Toolkits for Fluid-Structure Interaction 12 May 13, 2022 09:35
Strongly FSI scheme in OF WUYing OpenFOAM Running, Solving & CFD 0 January 26, 2022 00:29
LES, FSI, CFX, Yplus, VIV ... and problem! Pouya Main CFD Forum 5 October 30, 2012 13:12
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
