Question about interFoam continuity equation
Old   August 4, 2024, 06:15
Default Question about interFoam continuity equation
rosssslee is on a distinguished road
Hi!
May I have a question about how the continuity equation is handled in interFoam?
I understand that two incompressible phases are involved in interFoam and pEqn.H does the pressure correction:
Given two phases A and B and assume a volume fraction of A as \epsilon:
We may know that:
\frac{\partial \epsilon_{A} \rho_{A}}{\partial t} + \nabla \cdot (\epsilon_{A} \rho_{A} U) = 0.
However, I did not see any terms in pEqn.H to denote the first term about the evolution of density. Only the divergence of the velocity is considered in the pressure correction.
I check other multiphase solvers like interIsoFoam or multiphaseInterFoam, and they might inherit the pEqn.H from the interFoam, does it mean the continuity of rho is solved dependent on the phase interface function instead of a consistent pressure equation?
Please correct me if I miss some codes or some misunderstanding.
Thank you for any suggestions!
Lee
rosssslee is offline   Reply With Quote
Old   August 4, 2024, 09:11
Lucky
phi is mass flux
transport of mass mass flux integrated over the volume is mass continuity
incompressible flow, interfoam, twophase fluid
Adding diffusion term to interFoam transport equation Gearb0x OpenFOAM Programming & Development 3 February 14, 2023 05:16
Continuity Equation for multicomponent simulation lordluan CFX 15 May 19, 2020 19:36
Question about interFoam Solver Kahnbein.Kai OpenFOAM Running, Solving & CFD 2 August 26, 2019 16:36
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
