August 2, 2024, 00:29 |
Macroscale modelling
Mohnish Soral
I want to create a zig-zag scan pattern for simulating 3d printing of rectangular part in AM PravaH. I have created the scan pattern for single track and attached a screenshot with this thread. Anyone can suggest how to create a zig-zag pattern for my simulation?
August 3, 2024, 01:00 |
pruthvi utturwar
Rep Power: 2 |
Hi, you will have to calculate the x y z coordinates first for your scan pattern. You may use python script to generate the coordinates. lets say you have a rectangle with width W and height H, depending on hatch spacing you will divide the W and H. lets say your hatch spacing is W/4 so width will be divided into n1 = 4 parts and height will be divided into n2 = H/(W/4) parts. Now you have coordinates on H and W, join them to create zigzag lines. depending on the length of each of the lines and the scan speed, you can calculate the time respective time columns.
August 5, 2024, 07:45 |
Mohnish Soral
Thanks for reply pruts. it really helped.
3d printing process, additive manufacturing, multiphase flows |
How much does the source code for this turbulent flow CFD code worth in US $? | Dr Youssef Hafez | Main CFD Forum | 43 | January 4, 2023 01:13 |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Low-Re Modelling | doerschlott | OpenFOAM Running, Solving & CFD | 4 | June 23, 2022 06:53 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 04:59 |
