Auckland
Rep Power: 0 ![]() |
I get this error when I process simpleFoam after snappyHexMesh. I am trying to proceed with the cylinder flow example following the instructions as the end of the motorBike tutorial by Cyprien Rusu
--> FOAM FATAL IO ERROR: size 38792 is not equal to the given value of 74400 file: /home/john/OpenFOAM/john-11/run/cylinderFlow2/0/U from line 17 to line 53. |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Your U file contains 38792 elements but your mesh only contains 74400. This makes no logical sense and hence the error.
Try and figure out how this inconsistency arose. |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
