Gaurav Gupta
Rep Power: 2 ![]() |
I am looking for code to perform DNS of flow around complex geometries at moderate Re (20K -30K). Till now, I have been using Xcompact3D and Nek5000. Xcompact3d is good for flows till Re 5K max otherwise it is comutationally very expensive on the otherhand Nek5000 is fast but meshing around the complex geometry is difficult. So, I am looking for some alternative which is computationally fast as well as doesn’t require meshing. Thus, I have a few questions regd. that, 1. How much computationally expensive the code is for a DNS (Some example would be highly helpful in understanding)? 2. How acccurate is the method ? I am studying flow around UAVs through DNS. Thanks, Gaurav |
#2 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
A DNS formulation depends on the grid resolution not on the type of code. Any consistent code can work (theoretically) in DNS resolution, the issue is just in the correct grid to resolve all turbulence scales. A different matter is a LES code, there a many aspects to be considered. |
#3 | |
I don't follow as much Incompact, which might as well be used for industrial cases but, my point here is that it isn't, formally speaking, traditional as it uses immersed boundary. If you are willing to move even forward then from traditional, you could look at Lattice-Boltzmann codes, which also rely on the immersed boundary concept. I'm not into them but, according to their marketing materials, they can do marvels of any kind and complexity, and seem to be on the scale-resolving side of the matter (altough, I have several personal concerns about their definitions of LES and DNS) |
dns; codes; suggestion; |
How are combustion CFD codes implemented ? | aerosayan | Main CFD Forum | 2 | May 24, 2022 00:10 |
CFD Salary | CFD | Main CFD Forum | 17 | January 3, 2017 17:09 |
CFD CODES FOR MARINE APPLICATIONS | 1995JAL | Main CFD Forum | 2 | August 19, 2006 07:40 |
Can we quantify the fruits of CFD? | Brady Brown | Main CFD Forum | 14 | December 15, 1999 09:42 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
