UnicodeDecodeError : 'utf-8' codec can't decode byte 0x89 in position 48 : invalid st |
Antoine
Rep Power: 2 ![]() |
Hello everyone.
I am trying to make my first simulation using DAFoam. However, I am meeting some issues after the first coloring steps. On the first screenshot, we can see that there is a first error occuring about "addGeoDVLocal" (addGeoDVLocal will be deprecated, use addLocalDV instead). I tried to update to pygeo 1.13.1 as mentionned on the following discussion (Compile from source problem : #309 have obtained the same result and I have finally solved that part by replacing with addLocalDV in my script. However, I have still an issue mentionning PETSC and the following error : (UnicodeDecodeError : 'utf-8' codec can't decode byte 0x89 in position 48 : invalid start byte) at the bottom. Can you help me with that bug ? 1st screenshot dc1.png 2nd screenshot dc2.png |
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? | Sorabh | OpenFOAM Meshing & Mesh Conversion | 1 | August 3, 2021 06:35 |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
parallel simulations - error message: "OPT_ITERATIONS: invalid option name" | v8areu | SU2 | 5 | July 23, 2015 02:57 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
