zygao
Rep Power: 2 ![]() |
I am using steady state to calculate dpm model and have set the mass flow rate of the surface injection. But what I'm not sure about is how long the surface injection has been jetting after the steady state calculations are done? I.e. how many particles were ejected in total by the surface injection source. Thanks!
#2 | |
Frederick Allison
Rep Power: 0 ![]() |
- Understanding Mass Flow Rate and Injection Duration boxing random - Calculate the Number of Particles Injected - Determine the Equivalent Time Example Calculation Let's assume: Mass flow rate ( 𝑚 ˙ m ˙ ) = 0.01 kg/s Mass of a single particle ( 𝑚 𝑝 m p ) = 1e-6 kg Equivalent time ( 𝑡 t) = 1000 seconds (as an example for calculation) Using the formula: 𝑁 = 0.01 kg/s × 1000 s 1 × 1 0 − 6 kg/particle N= 1×10 −6 kg/particle 0.01kg/s×1000s 𝑁 = 10 kg 1 × 1 0 − 6 kg/particle N= 1×10 −6 kg/particle 10kg 𝑁 = 10 × 1 0 6 particles N=10×10 6 particles 𝑁 = 10 , 000 , 000 particles N=10,000,000particles |
#3 | |
zygao
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
file injection.: continuity fail; volume injection.: wrong total mass | blerli_91 | Fluent Multiphase | 6 | October 2, 2018 05:34 |
surface injection | maczaj | FLUENT | 0 | June 11, 2015 05:42 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
