sasha
Rep Power: 4 ![]() |
Hello everyone, hope you are doing well
I want to generate a prism on my geometry which looks like a gearbox, but although the geometry quality is ok I keep getting this error: prism terminated prematurely! I searched a bit and found out it would be because the layers on different faces of the surface encounter each other, I dont know if I could properly explain what I mean but here is images of the geometry what should I do to generate a prism around this surface???? for now I generated density around it, but I know it wouldn't work as prism I would appreciate any answers ![]() Screenshot (202).jpg Screenshot (199).jpg |
sasha
I found the solution, for those who are seeking an answer, you need to edit your geometry and deselect the surfaces in the middle and choose a name for the new surface without the middle ones, then in ICEM try prism on the new surface. I attach a pic to clarify what I mean by middle surfaces and also a pic of the mesh with prism.
hope it helps 1.jpg Screenshot (204).jpg |
cfd, fluent, icem |
[ICEM] prism meshing | kar1209 | ANSYS Meshing & Geometry | 0 | March 2, 2017 12:20 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 07:06 |
ICEM Prism Layer transition between surface with prism layers and one without | TWaung | ANSYS Meshing & Geometry | 2 | October 12, 2009 14:56 |
ICEM - Prism Tool Problem | carpe85 | CFX | 0 | February 10, 2009 12:25 |
Icemcfd: Preventing prism inflation collisions? | Joe | CFX | 1 | July 31, 2007 09:13 |
