2D incompressible cavity flow Matlab code NAN result |
June 6, 2024, 06:48 |
Sasha Prival
Hello. Newbie here. I am following this guide to create my very first simple CFD solvers for incompressible 2D fluid in a lid-driven square cavity. In the guide, the pressure is considered with zero-derivative Neumann BCs imposed on all boundaries. I have managed to write and run a Matlab code following the guide. It runs fine.
Then I wanted to change the top boundary condition for the pressure to 0 Dirichlet like in the Step 11 of famous beginner guide of Lorena Barba. I have modified the Laplacian matrix contents to include top Dirchlet BC. Assigned 0 to the corresponding elements of the source (right-hand side) vector. Forced 0 value to the corresponding elements of the solution (pressure) vector. Here is the complete Matlab code I wrote: Code:
clear; clc; % grid parameters Lx=1; % x length Ly=1; % y length nx=41; % number of grid points along x ny=41; % number of grid points along y %simulation parameters dt=0.001; % time step t_final=5.0; % simulation run time % Number of timesteps Nt=t_final/dt; % physics parameters rho=1.0; % density nu=0.001; % viscosity coefficient (kinematic) % Index extents imin=2; imax=imin+nx-1; % ok jmin=2; % ok jmax=jmin+ny-1; %create mesh sizes dx=Lx/(nx); dy=Ly/(ny); dxi=1/dx; dyi=1/dy; % preallocate important arrays p=zeros(imax,jmax); % pressure array %p=zeros(nx,ny); % ok us=zeros(imax+1,jmax+1); % u - velocity without pressure vs=zeros(imax+1,jmax+1); % v - velocity without pressure R = zeros(nx*ny, 1); % RHS of Pressure Poisson Equation u=zeros(imax+1,jmax+1); % corrected u v=zeros(imax+1,jmax+1); % corrected v L=zeros(nx*ny,nx*ny); % Laplacian matrix % initial values t=0; % initial time u_bot=0; % initial velocity for bottom wall u_top=1; % initial velocity for top wall v_lef=0; % initial velocity for left wall v_rig=0; % initial velocity for right wall % Creat Laplacian operator for solving pressure Poisson equation for j=1:ny %number of block matrices along y for i=1:nx %number of block matrices along x q = i+(j-1)*nx; %if(mod(q,1*nx)==0) if (q > (nx-1)*ny) % if top boundary L(q,q)=1; % Zero Dirichlet condition else L(q,q)=-(2*dxi^2+2*dyi^2); for ii=i-1:2:i+1 if (ii>0 && ii<=nx) % Interior points L(q,ii+(j-1)*nx)=dxi^2; else % Neuman conditions on boundary L(q,q)= L(q,q)+dxi^2; end end for jj=j-1:2:j+1 if (jj>0 && jj<=ny) % Interior points L(q,i+(jj-1)*nx)=dyi^2; else % Neuman conditions on boundary L(q,q)= L(q,q)+dyi^2; end end end end end %disp("L="); disp(num2str(L)); % solver disp("Starting simulation ****************************"); while t <= t_final % update time t = t + dt; clc; disp("t:"); disp(t); u_top=1; % u velocity predictor for j = jmin:jmax for i = imin+1:imax v_here = 0.25*(v(i-1,j)+v(i-1,j+1)+v(i,j)+v(i,j+1)); us(i,j)=u(i,j)+dt* ... (nu*(u(i-1,j)-2*u(i,j)+u(i+1,j))*dxi^2 ... +nu*(u(i,j-1)-2*u(i,j)+u(i,j+1))*dyi^2 ... -u(i,j)*(u(i+1,j)-u(i-1,j))*0.5*dxi ... -v_here*(u(i,j+1)-u(i,j-1))*0.5*dyi); end end % v velocity predictor for j = jmin+1:jmax for i = imin:imax u_here = 0.25*(u(i,j-1)+u(i+1,j-1)+u(i,j)+u(i+1,j)); vs(i,j)=v(i,j)+dt* ... (nu*(v(i-1,j)-2*v(i,j)+v(i+1,j))*dxi^2 ... +nu*(v(i,j-1)-2*v(i,j)+v(i,j+1))*dyi^2 ... -u_here*(v(i+1,j)-v(i-1,j))*0.5*dxi... -v(i,j)*(v(i,j+1)-v(i,j-1))*0.5*dyi); end end % compute R.H.S. (R) of the PPEquation using vs & us. n=0; %R = zeros(nx*ny, 1); % RHS of PPEquation for j=jmin:jmax for i=imin:imax n=n+1; R(n)=(rho/dt)*((us(i+1,j)-us(i,j))*dxi+(vs(i,j+1)-vs(i,j))*dyi); % if(mod(n,nx)==0) if (n > (nx-1)*ny) % if top boundary R(n)=0; % force 0 value end %disp(["R[",n,"]:",R(n)]); end end % Find pressure solution vector using direct method pv=L\R; % disp("pv="); disp(pv); n=0; p=zeros(imax,jmax); % convert pressure vector into mesh array for j=jmin:jmax for i=imin:imax n=n+1; % if (mod(n,nx)==0) if(n > (nx-1)*ny) % if top boundary pv(n)=0; % force Zero Dirichlet end p(i,j)=pv(n); end end %disp("p="); disp(num2str(p)); % correcting (updating) u & v velocities for j=jmin:jmax for i=imin+1:imax u(i,j)=us(i,j)-(dt/rho)*(p(i,j)-p(i-1,j))*dxi; end end for j=jmin+1:jmax for i=imin:imax v(i,j)=vs(i,j)-(dt/rho)*(p(i,j)-p(i,j-1))*dyi; end end % set Boundary Conditions u(:,jmin-1)=u(:,jmin)-2*(u(:,jmin)-u_bot); u(:,jmax+1)=u(:,jmax)-2*(u(:,jmax)-u_top); v(imin-1,:)=v(imin,:)-2*(v(imin,:)-v_lef); v(imax+1,:)=v(imax,:)-2*(v(imax,:)-v_rig); end; disp("End of simulation"); disp("Last t="); disp(num2str(t)); disp("Last p="); disp(num2str(p)); disp("Last u="); disp(num2str(u)); disp("Last v="); disp(num2str(v)); disp("Finita!"); P.S. This is my first post here. Please kindly remind me of any "don'ts" I have made in the post if there are any. Thank you. |
June 9, 2024, 05:49 |
Sasha Prival
Is there someone who will give me some advice or help in anyway?
June 10, 2024, 13:30 |
Daniel
Rep Power: 9 |
Did you check at which loop it crashes? Did you print out your matrices? Maybe check the initialalization first and iterate once and recheck the flow field. Maybe there are any obvious problems already apparent
cavity flow, dirichlet pressure, matlab, nan error, neumann bcs |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
code for SIMPLE algorithm - 2D Lid driven cavity flow problem - Collocated grid | h_amooie | OpenFOAM Programming & Development | 1 | January 22, 2022 11:33 |
Matlab code for pipe flow | cici | Main CFD Forum | 72 | May 12, 2017 18:05 |
Need Help Here! nan value error | mgkid3310 | OpenFOAM Running, Solving & CFD | 1 | October 6, 2016 00:59 |
Cavity Flow Code | Adeel Khan | Main CFD Forum | 0 | April 20, 2014 03:08 |
