alya
Rep Power: 0 ![]() |
hi, this is very urgent.
i have a 3D model of blood vessel where blood flows inlet to outlet and interacts with solid objects in the center of the blood vessel. but in the cfd-post, it shows that blood passes through the solid objects without interacting with it as if the solid domain is not there. i have already defined the solid domain in the cfd-pre but i havent set up the domain interface bcs of errors of overlapping boundaries. how can i fix this? :'( |
Make sure your contact surfaces between the fluid and solid domains are well defined and without overlap. Sometimes it can be useful to check each boundary and adjust them manually so that they match perfectly. Remember also to check that your boundary conditions are correctly applied to each interface. A bit like a synchronized calendar where every event must be perfectly aligned to avoid conflicts, your domains must be well defined for the simulation to work properly. |
alya
hi, thanks for replying!
how do i make sure it doesnt overlap? |
blood flow, cfx, fluid structure |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 13:39 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Number of time step in Transient structure for Fluid Structure interaction | YANNAPOL | Structural Mechanics | 1 | July 5, 2015 08:41 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
