can energy equations be written in conservative form? |
May 22, 2024, 13:36 |
Matthew
Rep Power: 4 |
The mass and momentum equations can usually be written in conservative form which is useful for the finite volume method. My question is: Can the conservation of energy be written in this form? I'm thinking of an application of solid mechanics where you have movement.
May 22, 2024, 14:29 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
The total energy has indeed a conservation form! You can find that in any fluid mechanics textbook |
May 22, 2024, 21:55 |
Lucky
Rep Power: 66 |
In case there is any doubt.... see Noether's theorem
May 23, 2024, 08:20 |
#4 | |
Rep Power: 73 |
Here is the form |
May 23, 2024, 10:46 |
Matthew
Rep Power: 4 |
May 23, 2024, 11:40 |
#6 | |
Rep Power: 73 |
Actually, this is the balance equation for the temperature. It is the quasi-linear form of the internal energy (rho c T). No one of such variables has a conservation property, only the total energy does. Even if you write the temperature equation in integral form, that is not a conservation equation, you have a production term. |
June 3, 2024, 06:44 |
#7 | |
Matthew
Rep Power: 4 |
June 3, 2024, 07:37 |
#8 | |
Rep Power: 73 |
You can write an integral equation for the internal energy, however it has a production term that remains in the form of volume integral, you cannot use Gauss to convert in the surface integral of the fluxes. This is the form you can use for a FV discretization |
June 3, 2024, 09:26 |
#9 |
In summary, not surprisingly, you can write in fully conservative form only equations for fully conserved quantities. Total energy is fully conserved, not internal or kinetic separately.
June 3, 2024, 21:53 |
#10 |
Lucky
Rep Power: 66 |
Just to give a 3rd redundant answer...
Any transport equation works with FVM. FVM doesn't breakdown simply because you choose temperature (a non-conservative property) as your transport variable. You just integrate the production term (sources/sinks) over the volume and FVM still works. |
conservation of energy, conservative form |
Turbulence dissipation vs Viscous dissipation | granzer | Main CFD Forum | 18 | January 10, 2022 01:27 |
Conservative discretization | arungovindneelan | Main CFD Forum | 1 | July 4, 2019 04:22 |
Equations for conservative heat transfer at solid-porous interface in CFX | Chander | CFX | 1 | April 18, 2013 19:49 |
Equations in full form | Mark Render | Main CFD Forum | 3 | June 20, 2000 16:05 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 14:22 |
