Compressible flow
Old   April 24, 2024, 01:32
Default Compressible flow
lb
lb0331 is on a distinguished road
Hi, I'm running compressible flow simulations, studying orifice gas throttling. In the actual experiment, there is a 1bar gas chamber at the entrance, and atmospheric pressure directly at the exit. A density-based solver is used, and the operating pressure is set to 0. The fluid domain model and boundary condition values are shown in the figure. Since the inlet flow is not known, the boundary conditions use pressure inlet and pressure outlet. Now I am confused about some values of the boundary conditions and do not know whether they are set correctly.
For the entrance, the Gauge Total Pressure is 201325pa, but for Supersonic/Initial Gauge Pressure, I am not quite sure how much to set.
For exports, the Gauge Total Pressure is 101325pa
lb0331 is offline   Reply With Quote
Old   April 24, 2024, 11:08
Lucky
BC's look ok.
The supersonic static pressure is only required if the inlet is supersonic. Since your inlet is not supersonic, you do not have to worry.
Just to further explain, if the inlet becomes supersonic then you must specify stagnation and static pressure. For a subsonic inlet, you only need to specify stagnation pressure.
Old   May 9, 2024, 11:16
lb
Originally Posted by LuckyTran View Post
BC's look ok.
thank you for your reply
boundary condition
Compressible nozzle flow - no problem for fluent but impossible with openFOAM? flar.t OpenFOAM Running, Solving & CFD 10 March 30, 2022 02:21
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Natural Convection using Compressible Flow (chtMultiRegionFOAM) msarkar OpenFOAM 2 September 7, 2010 01:13
help with compressible flow BC's (need subsonic flow) meangreen Main CFD Forum 5 July 24, 2010 14:16
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 14:19
