flow in porous media
Old   August 31, 2000, 16:00
Default flow in porous media
Abdul Siahaan
Hi, Are there any possibility to get some source codes to simulate single flow in porous media? Thanks!
Old   September 1, 2000, 23:34
Default Re: flow in porous media
istadi
the source code computer of the flow in a porous media can be easily self developed. To get the literature about momentum balance and pressure drop of this problem, you can read in the books and papers. In this case, it is a paper about this problem: [Liu, S., and J.H. Masliyah, (1999),"Non-linear Flows in Porous Media", J. Non-Newtonian Fluid Mechanics, 86, pp. 229-252] So, we make a source code by F90 or other software and we get a profile of U, V, W momentum applied in a porous media.
For the application of the flow in a porous media , we can add the pressure drop force in Navier stokes- eqt. such Ergun, Darcy, Forcheimer, etc. depend on the system studied.
Old   September 3, 2000, 10:38
Abdul
Thanks for the reply and information. If you don't mind I would like to ask which method (finite difference, finite volume, ...) did you use?
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
Compressible flow through porous media? JoFFe CFX 2 November 1, 2010 05:50
no converge - for Low Re Porous media seepage flow lee CFX 3 August 31, 2007 02:12
Modeling porous media flow in prostar Nirmal Kumar Pathak Siemens 8 November 23, 2005 08:18
Flow resistance of porous media Desheng Kong Main CFD Forum 3 December 19, 2000 12:07
