Solving Navier-Stokes Numerically (Discretization)
Old   March 15, 2024, 17:24
Default Solving Navier-Stokes Numerically (Discretization)
Kokogu
kokogu is on a distinguished road
Unsteady, incompressible, laminar and fully developed flow inside a circular pipe can be expressed by following the 1D parabolic PDE form of the Navier-Stokes equation where u(r,t) is to be calculated.
\rho\frac{\partial u}{\partial t}=-\frac{\partial p}{\partial x}+\mu\frac1r\frac\partial{\partial r}\Big(r\frac{\partial u}{\partial r}\Big)
Boundary conditions for the problem are symmetry at the centre and no-slip on the walls. Initially, the fluid is at rest.
\begin{aligned}
& \frac{\partial u}{\partial r}(r=0, t)=0 \\
& u(r=R, t)=0 \\
& u(r, t=0)=0
\end{aligned}
kokogu is offline   Reply With Quote
Old   March 16, 2024, 00:30
Lucky
https://en.wikipedia.org/wiki/Crank%...icolson_method
see also the table on forward euler and backward euler for a very obvious hint on how to do those cases as well
Old   March 16, 2024, 04:30
Kokogu
Yup read it but, still, I cannot discretise the spatial term.
\frac\partial{\partial r}\left(r\frac{\partial u}{\partial r}\right)\approx\frac1{\Delta r}\left(r_{i+1/2}\frac{u_{i+2}^{j}-u_{i+1}^{j41}}{\Delta r}-r_{i}\frac{u_{i}^{j}-u_{i-1}^{j+1}}{\Delta r}\right)
Maybe like this? But I could not grasp why are we doing smth like this. Also I am gonna solve this with MATLAB
Old   March 16, 2024, 06:01
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
\frac\partial{\partial r}\left(r\frac{\partial u}{\partial r}\right)\approx\frac1{\Delta r}\left(r_{i+\frac12}\frac{u_{i+1}^{j}-u_{i}^{j}}{\Delta r}-r_{i-\frac12}\frac{u_{i}^{j}-u_{i-1}^{j}}{\Delta r}\right)
This is just the formula obtained by the successive discretization from the outer to inner operator d/dx using a centred second order discretization on the step dr.
This is done to avoid a larger stencil having the issue of the checkerboard modes.
FMDenaro is offline   Reply With Quote
Old   March 16, 2024, 06:27
Kokogu
Could you help me discretize this? For FTCS, BTCS, and Crank-Nicolson Method.
Old   March 16, 2024, 06:38
Since that seems a list of homeworks, start to code, when you have a specific question, ask here.
Old   March 16, 2024, 15:19
Lucky
If you don't discretize it, then it is a 2D PDE. Do you know how to solve a PDE? If you discretize it, then it becomes an algebraic formula (for FTCS) or it becomes a linear system (for BTCS and Crank-Nicolson). Do you know how to solve Ax=b? That's why you discretize it.
Furthermore, the general N-S and other important PDE's are non-linear. In this example you start with the parabolised navier-stokes which is linear to begin with. But discretizing a non-linear PDE also results in the same algebraic equations (for FTCS) and linear system (for BTCS and CN). The reason you are being assigned parabolised navier-stokes, is the discretization is simple and it facilitates learning how to discretize PDE's. Clearly if students struggle with discretizing the parabolised navier-stokes equations, then the full navier-stokes is even more daunting and then students baby-rage and quit prematurely.
btcs, discretisation, ftcs, navier stokes equation, navier-stokes solver
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
