Transfer porous coefficients from simple geometry to much complicated. |
March 14, 2024, 09:13 |
Łukasz Bolonek
Rep Power: 2 |
Hey everyone, I'm working on project to define porous coefficients in thin mesh filter in dryer appliance. To do that I have plan to make experiment to measure pressure drop through the mesh in the straight tube, then verificate it in simulation. But question is - is it possible to transfer calculated on the basis of expirement viscous and inertial coefficients to exact same mesh but in complicated geometry? I want to use those number in simulations of whole appliance so filter with mesh are put in device in completely different geometry.
I assume that pressure drop will be different due to complicated environement and other loses but first I wanna ask experienced people than me |
March 14, 2024, 16:23 |
Lucky
Rep Power: 66 |
The longest answer is yes
March 15, 2024, 04:08 |
Łukasz Bolonek
Rep Power: 2 |
Okay, so there won't be such a big difference to consider simulation isn't comparable to experimental data?
March 15, 2024, 09:34 |
Lucky
Rep Power: 66 |
Well yes.
You have to understand that the theory of Linear Isotropic Homogeneous media is a model for linear and isotropic and homogeneous media. You can perform experiments to measure the properties of an ideal gas and then employ the ideal gas model to very complicated geometry. You can be awesome at CFD or you can be terrible at CFD, but that is independent from the task of measuring inertial and viscous resistance coefficients in a pipe. You can also be bad at experiments as well, that also is a possibility |
March 18, 2024, 04:19 |
Łukasz Bolonek
Rep Power: 2 |
Thank you very much then!
expirement, porous baffle |
Defining two different heat transfer coefficients for porous media model | student_1994 | Fluent UDF and Scheme Programming | 1 | May 2, 2019 01:25 |
Fluent - Flow/heat transfer over porous media - possibly interface issue | ayihan | FLUENT | 0 | March 3, 2018 19:55 |
Heat transfer through porous medium | myworkcfd | FLUENT | 0 | June 6, 2017 09:32 |
meshing problem with some complicated geometry | Parth320 | Mesh Generation & Pre-Processing | 1 | February 7, 2014 00:13 |
Heat transfer from porous medium to fluid | Ralf Schmidt | FLUENT | 1 | October 30, 2005 07:21 |
