Phase Change not Visible when Switching from Velocity Inlet to Pressure Inlet
Old   February 20, 2024, 21:14
Default Phase Change not Visible when Switching from Velocity Inlet to Pressure Inlet
bintang fikri
bintang is on a distinguished road
Hello everyone,
I am currently facing a challenge in simulating flow boiling using the Volume of Fluid (VOF) method in fluent. When I use the velocity inlet boundary condition, the simulation runs smoothly and successfully captures the phase change.
However, when I switch the boundary condition to pressure inlet, the phase change is not visible even though the pressure and temperature meet the conditions for phase change. I have ensured that simulation parameters and settings are correct.
I would like to ask for advice or guidance from all of you. Has anyone experienced a similar situation? Are there specific settings to be mindful of when using a pressure inlet for flow boiling simulation with VOF?
I truly appreciate any help or insights you can provide. Thank you very much!
[Bintang]
bintang is offline   Reply With Quote
Old   February 20, 2024, 21:24
Lucky
You need to specify the volume fraction at the inlet. Simply specifying temperature and pressure does not say anything about the phase of the material.
Old   March 18, 2024, 06:37
bintang fikri
Thank you, it's already working.
pressure boundary, vof multiphase, vof simulation
postprocessing result pressure in the inlet using simplefoam rjomega OpenFOAM Verification & Validation 0 March 20, 2022 03:39
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
Specify both velocity and pressure at inlet boundary NOD STAR-CCM+ 4 March 7, 2021 07:36
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
