February 15, 2024, 01:33 |
3D Bubble rising openfoam
onurlands
Rep Power: 2 |
Hello, I want to perform Bubble rising openfoam analysis in OpenFOAM. I want the object to move upward and into the atmosphere. Is there anyone who has solved the problem by performing the mesh operation from a different application, such as a program such as (Salome)? Also, is there an easy way to create complex objects in the setFielsdict file?
bubble rising, interfoam, interfoam bubble, openfoam |
Bubble rising in water too slow (imperceptible) in Fluent | Fluidpower | Fluent Multiphase | 8 | July 7, 2017 09:47 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
Messed up with the Rising Bubble :( | lowlow | OpenFOAM Pre-Processing | 2 | November 18, 2015 22:58 |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 19, 2014 23:42 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
