Conjugate heat transfer for heatedDuct
Old   February 5, 2024, 22:55
Default Conjugate heat transfer for heatedDuct
Mahsheed Rayhani
Mahsheed is on a distinguished road
Hello foam users,
I am a new user to OpenFoam and I am running a tutorial on heatedDuct based on chtMultiRegionFoam module. I have followed all the tutorial steps and now I am stuck at the last step of running chtMultiRegionFoam. Below is the error that I get. Also, I am using OpenFoam version 10.
can anybody help me with this problem?
Thank you,
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  10
     \\/     M anipulation  |
Build  : 10-c4cf895ad8fa
Exec   : chtMultiRegionFoam
Date   : Feb 05 2024
Time   : 21:35:58
Host   : "mahsheed-VM"
PID    : 10094
I/O    : uncollated
Case   : /home/mahsheed/OpenFOAM/My_tut/Heat_transfer/heatedDuct
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create fluid mesh for region fluid for time = 0
Create solid mesh for region metal for time = 0
Create solid mesh for region heater for time = 0
PIMPLE: Region fluid
PIMPLE: No convergence criteria found
PIMPLE: Region metal
PIMPLE: Region heater
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
*** Reading fluid mesh thermophysical properties for region fluid
    Adding to thermoFluid
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy;
    Adding to rhoFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to gFluid
    Adding to hRefFluid
    Adding to pRefFluid
    Adding to ghFluid
    Adding to ghfFluid
    Adding to turbulenceFluid
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
    Adding to thermophysicalTransport
Selecting thermophysical transport type laminar
Selecting default laminar thermophysical transport model unityLewisFourier
    Adding to reactionFluid
Combustion model not active: combustionProperties not found
Selecting combustion model none
    Adding to KFluid
    Adding to dpdtFluid
    Adding to fieldsFluid
    Adding MRF
No MRF models present
    Adding fvModelsFluid
    Adding fvConstraintsFluid
*** Reading solid mesh thermophysical properties for region metal
    Adding to thermoSolid
    type            heSolidThermo;
    transport       constIsoSolid;
    thermo          eConst;
    specie          specie;
    energy          sensibleInternalEnergy;
    Adding to fvModelsSolid
    Adding fvConstraintsSolid
*** Reading solid mesh thermophysical properties for region heater
    type            heSolidThermo;
    thermo          eConst;
    specie          specie;
Creating fvModels from "constant/fvModels"
Selecting finite volume model type heatSource
    - selecting all cells
    - selected 400 cell(s) with volume 4e-06
Region: fluid Courant Number mean: 0.000996623 max: 0.001
Region: metal Diffusion Number mean: 0.0823045 max: 0.329218
Region: heater Diffusion Number mean: 0.0222222 max: 0.0888889
volAvgHeaterT volAverage weight field none
volAvgMetalT volAverage weight field none
surfaceFieldValue volAvgInterface:
    total faces  = 80
    total area   = 0.0008
volAvgInterface areaAverage weight field none
deltaT = 0.001
volFieldValue volAvgHeaterT write:
--> FOAM FATAL ERROR:
Field none not found in database
    From function Foam::tmp<Foam::Field<Type> > Foam::functionObjects::fieldValues::volFieldValue::getFieldValues(const Foam::word&) const [with Type = double]
    in file fieldValues/volFieldValue/volFieldValueTemplates.C at line 62.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::tmp<Foam::Field<double> > Foam::functionObjects::fieldValues::volFieldValue::getFieldValues<double>(Foam::word const&) const at ??:?
#3  Foam::functionObjects::fieldValues::volFieldValue::write() at ??:?
#4  Foam::functionObjectList::start() at ??:?
#5  Foam::Time::run() const at Time.C:?
#6  ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#7  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9  ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
Aborted (core dumped)
Mahsheed is offline   Reply With Quote
Old   February 6, 2024, 10:55
Lucky
You try to write a field named volAvgHeaterT but this field name does not exist in the registry. Probably because you use a fieldFunctionObject in your controlDict that is not set up propertly. Dump the contents of this functionObject
Use the dedicated OpenFoam forum. Maybe actually follow instructions.
openfoam, thermal conductivity
No conjugate heat transfer between solid (cast iron) and fluid (water) part Rajaero FLUENT 5 June 25, 2023 04:07
Conjugate Heat Transfer In Porous Media gartz89 FLUENT 3 February 7, 2023 03:24
Cyclic conjugate heat transfer johanesp OpenFOAM Programming & Development 0 December 30, 2021 11:55
No conjugate heat transfer between solid (cast iron) and fluid (water) Rajaero Main CFD Forum 1 August 23, 2018 14:01
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
