February 1, 2024, 18:44 |
Airfoil Not Showing Up In ParaView
I'm trying to use OpenFOAM to find the lift, drag, etc. on an airfoil/wing section I have. If I'm using the 3D wing section, I do have an .stl file. If it's the airfoil, I have a set of x, y coordinates outlining the airfoil in a .dat file. I am trying to edit a tutorial that came with OpenFOAM to change out my .stl file currently. I've made adjustments in blockMeshDict and snappyHexMeshDict to replace the files and measurements used in the motorbike tutorial.
The problem I'm having is that the case runs without errors and allows me to send it to ParaView, but it's an empty box. The walls of the space show up and have pressure values, but the wing section itself isn't appearing inside. I'm also getting all zeros for lift, drag, etc. What could I be doing wrong? |
February 2, 2024, 01:35 |
M
Rep Power: 12 |
Your meshing failed. Do not perform a simulation unless you have checked your mesh first.
Without further information my best guess is that you introduced a syntax or other error in snappyHexMesh which caused it to fail. The blockMesh was created successfully, otherwise you would not have a mesh to run on. Obviously your drag etc. is zero with no obstacle for the flow. You can share more information here: https://www.cfd-online.com/Forums/openfoam-meshing/ (or maybe this thread gets moved there altoghether by an admin). |
openfoam, paraview |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
Airfoil with simpleFoam and kOmegaSST: high drag values? | Tsiolkovsky | OpenFOAM Running, Solving & CFD | 6 | November 21, 2018 05:56 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
