Difference in Numerical and Simulation results |
January 25, 2024, 23:07 |
Ali Qasim
Rep Power: 2 |
Hi everyone,
I am modeling a cross-flow energy exchanger for heat transfer from humid air to a cold fluid separated by the membrane. I have performed the simulation and for validation purposes, compared the results with experimental results and analytical calculations. I used the effectiveness-NTU method for the analytical calculations of sensible effectiveness. Surprisingly, there is a huge difference between the analytical and numerical simulation values. I have used symmetry boundary conditions in numerical analysis (half domain is modeled with a half flow rate). In the case of analytical calculations, do I need to use “half domain with half flow rate” or “full domain with full flow rate”??? In both cases, the results are different. Regards, |
January 26, 2024, 22:36 |
#2 | |
Rep Power: 16 |
January 29, 2024, 20:16 |
Ali Qasim
Rep Power: 2 |
Dear CFDfan,
Thank you for your response. In the case of numerical simulation results, I am getting a sensible effectiveness of 94% according to specified mass flow rates of air and liquid solution. In this case, the half domain is modeled with the use of symmetry boundary conditions. I am a little bit confused with the selection of the domain to be used for the analytical calculations. So I have done analytical calculations with the following two cases: 1. Half Domain: In this case, I am getting very high values of effectiveness with most of the cases (changing flow rate), almost 98-99% of the sensible effectiveness. 2. Full Domain: In this case, sensible effectiveness is at ~80%. the difference in this case is high w.r.t numerical simulation. |
CFG file Set Up | Nicola_Fontana | SU2 | 5 | November 16, 2021 12:48 |
Irrational results with perfectly expanded nozzle simulation | Vishnu Sankar | SU2 | 3 | November 10, 2020 06:20 |
The results of the viv numerical simulation do not match the results of the paper | zxh666hahah | OpenFOAM Verification & Validation | 0 | September 5, 2020 01:28 |
problem numerical results of lift and drag in airfoil simulation using fluent solver | Mohammad1994 | FLUENT | 0 | June 7, 2018 02:59 |
Ahmed body simulation gives unexpected results in su2 6.0 | anas651 | SU2 | 0 | March 28, 2018 03:42 |
