January 10, 2024, 13:56 |
CGNS Library Modifications for CFD Solver
CFDReiziger
I am new to the CGNS library and currently working with an in-house CFD solver where CGNS is utilized for writing the solution. My objective is to rewrite the solution file (solution.cgns) to include one or more additional arrays. Specifically, I aim to map fields A/B/C/D to A/B/E/G. In OpenFOAM, achieving this is possible using mapFields. The optimal approach seems to be utilizing the CGNS library. Could you please provide some guidance on where to start? Thank you very much for your help. Last edited by CFDReiziger; January 11, 2024 at 09:40. |
January 10, 2024, 14:34 |
#2 | |
ONESP-RO
Rep Power: 5 |
I believe that your question is not clear. Please take a look at this link: Guide: How to ask a question on the forums Kind regards
Don't keep making the same mistakes. Try to make new mistakes. |
January 13, 2024, 13:11 |
Joern Beilke
Rep Power: 20 |
You might have a look at
https://github.com/CGNS/CGNS/discussions |
January 23, 2024, 13:00 |
CFDReiziger
Thank you, Joern, for your suggestion. I will definitely have a look at the website your provided.
cgns file edit, cgns file read |
Error SIGSEGV using VOF and UDF | JERC_UTFSM | Fluent UDF and Scheme Programming | 14 | November 8, 2021 00:17 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 06:40 |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 16:44 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 08:53 |
CGNS unstructured in own solver | nico | Main CFD Forum | 3 | May 18, 2006 17:31 |
