December 28, 2023, 02:21 |
CFD_DEM Coupling- Particle drying
Aniket
Rep Power: 3 |
Hello Everyone,
I am trying to simulate the particle drying using Fluent and Rocky DEM two way coupling. In DEM there is one module ' CFD Particle Drying Model '. In Fluent setup I have used Eulerian Multiphase model (2 phases air and water vapor [solid phase will be solved by RockyDEM]) with species transport (mixture templete air +vapor). In DEM I have used CFD particle drying model, to which the required moisture conent has been given. The coupling option is chosen as '2 way unresolved'. But when solving in DEM it is giving me this error: Capture.PNG I am unable to understand the source of this error. How can i fix this error? Thank you !!! |
January 8, 2024, 23:09 |
Jiaming
Hello, how your problem, I encountered the same problem as you, please give some advice. Thank you for your help!
July 28, 2024, 01:45 |
Ji Guozhao
Rep Power: 15 |
I got the same issue as well. Still struggling with it for many many days.
Need suggestions about technical difficulties - Drying + Pyrolysis of coal particle | Kummi | OpenFOAM Running, Solving & CFD | 12 | April 26, 2022 14:24 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 17:30 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 15:11 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
